Question about Plantronics CS55/HL10 Wireless Office Headset System with Lifter 69702-01 Headset
Headset microphone sound breaks up
The earpiece sound works great but the headset microphone sound tends to break up and become intermittent after anywhere from 2 to 15 minutes into a call. I have replaced the rechargeable battery but that did not fix the microphone break up. Others in my office have experienced the same problem. We have had our CS55 headsets for about a year.
  • 1894 Answers
SOURCE: Plantronics CS55 headset.
yes change the battery sir
also can be due to shorting
Posted on Jun 19, 2008
  • 32 Answers
SOURCE: I have plantronic headset model CS55 the green light is blinking
Either the battery is low, or the unit is switched on.  If you're looking at the base unit of the CS55, on the right hand side there is a switch that either points to I or II.  If it's on II, your headset will be activated the second it is removed from the base.  If it's on I, it won't turn on, thus it won't turn the light on.  Check to make sure that dial is on I instead of II, and when you pick it up you shouldn't have that problem anymore.
If it's a problem with low battery you have to make sure that when you place the headset on the charging cradle that it's securely seated in there.  Also make sure that you clean the charging contacts (the brass-coloured contacts on the headset and on the base) about once a month with rubbing alcohol.
Posted on Apr 28, 2009
  • 32 Answers
SOURCE: phone doesn't ring in earpiece
Only if you have an HL-10 lifter installed... you will then be able to hear three short beeps in your ear to indicate the phone is ringing.
  • 32 Answers
SOURCE: PL-CS55 headset lifts receiver but only get buzzing sound in
Try a system reset:
1. Lift the headset off of the charging cradle (the base).  Make sure the headset is turned off.  The green light on the base won't be on if the headset is turned off. 2. Hold down the call answer button on the headset at the same time as mute button.  The mute button is found on the little black wheel on the top of the headset.  Use the tip of your finger to push it straight in. 3. Hold both buttons until you see a green light on the headset flash.  It will be right below your thumb.  Hold both buttons until the green light flashes for a series of 2 flashes.  Then let go of both buttons. 4. Put the headset back on the charging cradle and wait 30 seconds.  Lift it back off and try again. 5. If this doesn't work repeat the process once more or try a resubscription.
Resubscription procedure:
1. Put the headset back onto the charging cradle.  Make sure the red light on the base is on and the yellow light is flashing. 2. On the back of the base there are two buttons for the microphone adjustment that can be pressed down.  Press both of those down until the red light and yellow light on the front of the base start flashing. 3. While the headset is still on the charging cradle press and hold the mute button until the red light on the base goes solid, and the yellow light stays flashing. 4. Unplug the power to the base and then plug it back in. 5. Wait 20 seconds and try.
Posted on May 22, 2009
SOURCE: I need a manual for a CS55 Wireless offcie headset system
Try http://the-manuals.com/cs55-wireless-headset-manual/
Posted on Jan 15, 2010
Headset not recognized
Have you tried a new headset they tend to break contact with the 3.5mm jack. If that doesn't work them buy an official Samsung headset because some phones are picky
Feb 10, 2015 | Samsung Galaxy 3 I5800 Cell Phone
Repair cable on shure wireless headset mic
If you unplug the mic, does the crackling stop? It so, replace the mic.
Feb 03, 2012 | Shure THD Wireless Headset Microphone...
Bought new dynex dx-740 earclip headset with microphone. earpiece works but computer not picking up microphone.
Have you installed the software for your headphone? Your computer might not pick up your device because it doesn't recognize the device.
Mar 06, 2011 | Dynex Earclip Headset with Noise-Canceling...
I can't hear my friends but they can hear me on my xbox headset
It sounds like your headset is worn out. We are constantly replaceing them at my house. The little wires inside the cord where they go into the plug end tend to break and fail to give good/reliable conection.
You can try cleaning the plug end and checking that the receptical in the controler is free of debris, if that works great, if not buy a new headset.
Good luck
Mar 20, 2010 | Microsoft Headset for Xbox 360
Logitech USB Gaming Headset only working out of one ear
I've had this happen twice with Logitech headsets and believe it has to do with the cheap/fine wire they use in the cables. I suspect that a good tug on the cable will snap the wire or some other internal connection.
Aug 25, 2009 | Logitech Premium Headset
Computer Does Not Detect Headset Microphone
Sound and Recording jacks stop working on the DV6000 series due to the ribbon cable running under the power button. when the power button is pushed it bends the flex cable and over time it breaks the connection rendering the front jacks useless you can buy a new upper button panel for about 20 dollars on ebay
Aug 02, 2009 | HP Pavilion dv6000z Notebook
Nokia 6070 stays in headset mode w/o headset pulled in
Try restoring factory settings which is in settings
Jul 09, 2009 | Nokia 6070 Cellular Phone
Microphone does not work
you have to reset the head set by pressing the base button and the earpiece button toghether for about 10 sec and the system will be on factory settings.
Jul 08, 2009 | Plantronics PL-CS55 Wireless Headset
Dynex Earclip Headset with Noise-Canceling Microphone driver
ok umm....it is a noise canceling microphone, the earpiece works but when i talk into the microphone no one on the internet can hear me please help me with my dynex earclip headset
Aug 08, 2008 | Dynex Earclip Headset with Noise-Canceling...
Plantronics CS55/HL10 Wireless Office Headset System with Lifter 69702-01 Headset Logo
236 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
