Question about Maytag Washing Machines
Water is running straight out of washer instead of filling up
  • bhjaynes Jul 13, 2010
    drain hose is in correct position water continues to run through the washer without filling up Maytag Centennial commercial technolgy top load
  • 1,284 Answers
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
Take care
Posted on Jul 13, 2010
  • 6,784 Answers
HI. This is,essentially, a siphoning issue. The drain hose might be too low. Make sure the drain hose is at least three feet above the floor. Make these adjustments, asap. This should correct the issue.
  • 2 more comments
    drain hose is where it has always been
  • Michael Masters
    Michael Masters Jul 13, 2010
    There are no other causes for this. This is not an electrical issue or a mechanical issue. This type of problem is caused by an installation problem in the drain hose. Check to see if the drain hose is stuck way down the standpipe behind the washer. It should only be stuck down about 8" into this pipe. Otherwise it can cause the siphoning that you are experiencing.If the top of the stand pipe is taped shut so that it is air tight, you can also experience the siphoning as well.
    If you are draining the washer to a sink, the sink must be at least 39" high. If you are draining the washer directly into the yard or a floor drain of your home, an inadequate siphon break in the drain hose can also cause siphoning. This is gravity related. Check the hose as stated above and measurements with a tape measure.
    There are additional possibilities, but i will need your model number to make sure your pump has a flapper. If this is the case, the flapper may be worn, thus, allowing water to pass through during the filling process, or the lever which activates the flapper may not be getting pushed back
    into place after pump out.
    Post the entire model number, asap.
  • Michael Masters
    Thanks for waiting for my response......
  • Michael Masters
    Good luck..
Smart Drive machine on starting, water runs straight through into drain, thus not filling up
Most likely the water coming into the washer through the Water Inlet Valve could be siphoned out to the drain pump and out the drain hose because of an issue with the pump or plumbing. Is your washer overfilling?Is the washer detecting an overheat error? Observe carefully as to what part of the washing cycle the water is draining out. By watching the washer as it goes through its wash cycle, you can find out which part or error is causing the Washing Machine To Not Fill With Water and Keep Draining issue.
Washing Machine Will Not Fill With Water Keeps Draining How To Fix
Dec 03, 2017 | Washing Machines
Frigidaire washer goes straight to agitation and won't fill with water.
IN UNIT THERE IS A SENSOR OF PRESURE WICH HAVE A TUBE FROM WATER CUVA , and when fill water presure high from tub activate membrana and cicle startit ;may there a problem and also at ev . of in water, chec connection and clean dirt but with main out
Nov 04, 2012 | Frigidaire Washing Machines
Won't stop running water
does it over fill or does the water just keeps running in if it does the stand pipe is to low and needs lifting should be i meter from the ground
Sep 27, 2012 | Kenmore Washing Machines
ModelWJRE555OH1WW. MACHINE GOING STRAIGHT TO WASH INSTEAD OF FILL UP WITH WATER.
Remove the front panel and check for a pinched water level tube..
OR
the air dome on the side of the washer is clogged with soap.
OR
The water level switch is bad.
Open the control console to find a service manual to show how to open the machine and service the parts.
Jul 11, 2010 | GE Washing Machines
Whirlpool LXR9245EQ2 top loading washer tub won't fill
try taking the knob off and see if the nut is tight on the timer,it might if came loose
Jun 18, 2009 | Whirlpool Washing Machines
Whirlpool LXR9245EQ2 tub won't fill at beginning of cycle
HI, you have a combination issue. the Water fill level pressure switch and, the cycle selector switch are both damaged and, they should be replaced. the total cost of these switches will run you about $90.00.
We recommend the hands of a skilled service tech when repairing this type of electrical issue.
Washer does not fill with water
The problem is most likely that your drain valve is defective. If this happens, the water will pump out instead of circulating. There may also be something stuck in the drain valve causing it to stay open.
If you need more help, post a comment.
Thanks,
Tim
May 28, 2009 | Bosch 24 in. SGS43C12 Classixx...
Washer will not fill with water
I solved the identical issue that I was having with my washer, maybe it will help you: I opened the front panel to the washer and found a clear plastic line running down the inside; it had become clogged. Could tell, because disconnecting the line caused the washer to function. Removed clog and it seems to run fine now.
Oct 30, 2008 | Whirlpool LTE5243D Top Load Stacked...
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
49 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
