Question about Air Hogs Havoc Heli Helicopters
Heli keeps spinning one way even when I trim it.
Does the tail of the hilcopter mater if it is broken? Even when I hold it I can fell that it is going to spin if I let it go. Can you help ME =)
dontdiy
  • 8 Answers
SOURCE: Air Hogs Micro Havoc Heli spins wildly
The tail rotor on a helicopter is what controls the spin.
Posted on Dec 26, 2008
  • 11 Answers
SOURCE: problem with the back rotor.
make sure there is no debris such as hair thread or string caught in the back rotor. this will cause it to lock up. Remove it and try fiddling with the trimmer button to help it stop spinning the helicopter
Posted on Jan 08, 2009
  • 9 Answers
SOURCE: My Havoc Heli got wet
must be off, air dry, or in a warm place for a few days. then fully charged.you might have damaged the battery by getting it wet, if so the only choice is replace the battery.usually dried and charged is enough though.the lights require less power to run than the motor, thats why they continue to work even though the motor doesn't. Also make sure the battery is really full.watch for the lights on the charger (controller) to cycle,new batteries in the charger take about 15 min. to give a good charge.Good luck!
Posted on Jan 26, 2009
  • 6 Answers
SOURCE: My Havoc Heli is really hard to control and I need help.
You have to keep tapping the right trim button. Keep tapping it until it stops spinning. If the spinning stops and it just turns, Use the the left right moving analog un til it flies straight.
Posted on Jun 30, 2009
  • 6 Answers
SOURCE: spinning no matter what i do
the cause of this issue is hair or something preventing the tail rotor to spin properly.. i had this issue and checked mine over very good, noticed the hair in tail rotor, and then took a needle to fish IT ALL out.. if u dont get it all.. it wont trim properly cause it cant spin fast enough
Posted on Apr 13, 2010
My heli takes off and will slowly begin to make large circles spinning out of control.
TRY ADJUSTING THE TRIM ON THE TAIL ROTOR AS THIS IS WHAT KEEPS IT FROM SPINNING
HOPE THIS HELPS
Aug 21, 2011 | SYMA Toys industrial New Syma S107 Radio...
My helicopter has no lift even when fully chargered. The props are spinning but it just stays on the ground.
i got a new model havoc heli and the trim buttons did not help at all... in the end I took a motor/prop off of an air hog styrofoam plane I had that was identical to the havoc heli tail rotor and swapped em out.. Problem solved... there was some sort of error with the tail rotor
Mar 22, 2011 | Air Hogs Spinmaster Air Hogs Havoc...
Spinning syma s006 doesnt take off
the tail rotor keeps it from spinning thats its job
May 07, 2010 | SYMA Toys industrial Syma S006 Alloy Shark...
Apache havoc micro... can not trim the helicopter it spins counterclockwise.
Mar 02, 2010 | Air Hogs Havoc Heli Helicopters
Have a 5#10. Even on full battery the tail wobbles left to right and the heli rotates right continually even when trimmed fully to the left - can you help?
REMOVE CONTROL HORNS AND SET SERVOS TO CENTER POSITION WITH RADIO AND RECONECT HORNS TO SERVOS ,COULD HAVE SLIPPED ON SERVO SPLINES DUE TO A HARD LANDING.
Jan 20, 2010 | Walkera HM5#10 RC Helicopter
Spins to left non stop and trim wont correct it
Dec 26, 2009 | Air Hogs Havoc Heli Helicopters
Mar 15, 2009 | Air Hogs Havoc Heli Helicopters
Spinning no matter what i do
Issue: Heli spins to the Left (counterclockwise) uncontrollably.
Problem: Tail rotor not turning fast enough, Dragging.
Background: My son's Heli Cage also started spinning to the left after he had flown it a couple 3 times. The trim and direction stick could not compensate. One time, the tail rotor came off during a crash. It was put back on and ran fine a couple more times until the dreaded left spin. I began to troubleshoot the issue. I checked for damage, hair and whatever else on the shaft. There was no obvious signs. When I pulled the tail rotor off, I noticed that it came off very easily. I put a new one on it and problem solved.
Diagnosis: the tail rotor shaft was spinning inside the rotor. This prevented the tail rotor from turning the correct speed.
Corrective Measures: replace rotor with new one. Avoid hitting the rotor while it is spinning...good luck! :-)
Mar 02, 2009 | Air Hogs Havoc Heli Helicopters
Need blade for world tech skyhawk helicopter
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Dec 23, 2008 | Toys
Tail rotar
Yes - it matters for any heli.
The main rotor creates drag which makes the heli want to spin - the tail rotor pulls the heli in the opposite direction to compensate and keep it steady.
Look at the angle of the main rotor in regard to the direction it turns - you'll see how it 'pulls' upward. The tail rotor will need to 'pull' sideways, according to whichever direction the tail rotor is spinning.
I'm assuming you're reattaching a tail rotor or rewiring a motor?
Nov 19, 2008 | RC Airwolf Rc Electric Helicopter Body...
Air Hogs Havoc Heli Helicopters Logo
182 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
