Question about Intermatic EJ500C - Indoor Digital Wall Switch Timer - Astronomic Feature
In initial install, in setup mode i the device will not accept any hour change. I have reset several times & device does cycle thruogh per instruction to seup but will not accept input from + and - buttons, hep
  • 15,935 Answers
What is the model # of the switch please?
Thanks!!
Posted on Jul 13, 2010
How to reset tablet
From the Kurio web site FAQs:
WARNING: a factory reset will erase all the content of the internal memory of your tablet, including all apps, games and files you save in this internal memory. To keep your files, please move it to the external SD card first.
This procedure shall not be done unless you were instructed to do so by the Tech Support or if you want to really restore the unit to its initial state.
After the reset, all preloaded applications and games must be reinstalled. To be able to reinstall all the initial content, please download the preload pack file here.
Once the preload pack downloaded, unzip the file on your desktop to have a folder named "recover", then follow these steps:
1) Go to Settings / Backup & Reset and select the option "Factory Reset". The system will ask you to confirm several times.
2) The tablet will automatically reboot (reboot can take some time after a reset) and start the setup : DO NOT perform the setup yet. On the first step of the setup (language selection), connect the tablet to your computer and copy the folder "recover" on the root of your internal memory. Once the copy is finished, press the Power button of your tablet until the popup message shows up and press OK to turn off the device.
3) Turn on your tablet by pressing the power button 3 seconds : after the loading screen, the device will automatically install all preloaded applications : this operation can take up to 40 minutes depending of the number of apps to installed...be patient and ensure your device has enough power. In case of doubt, make sure it is plugged to the mains.
4) After the installation, the initial Kurio Setup will restart automatically: follow all the steps of the setup as when you initially set it up.
IMPORTANT:
- After resetting and reconfiguring your device, please make sure that the date and time are correct. Some Kurio features, such as the content filtering software, may not work properly if the system shows the wrong date & time.
- if you created profiles and setup the Kurio Store before the reset, it is important to use the same profile name as before the reset so that the account can be restored.
May 16, 2014 | Techno Source Kurio Kids Tablet With...
No signal
1.Turn the device off and back on. Most service issues are due to old, timed-out registrations that have dropped you from the network. By power-cycling the phone, a new registration is acquired and signal should be restored.
2.Perform a Master Reset. If power-cycling did not restore your service, the problem may be due to a software issue. Doing a master reset will revert the software back to factory standards, restoring your service by removing bugs that may have developed over time. Generally this is done by pressing "Menu," "Settings," "Initial Setup" and "Master Reset." However, steps may vary from device to device so refer to your user manual for different steps if needed.
3.Perform a Master Clear. If the master reset did not restore your service, the software issue at work may be severe. In this case, it is necessary to completely wipe all information from the device and install a fresh copy of the operating system using the Master Clear function. Press "Menu," "Settings," "Initial Setup" and "Master Clear." Again, steps may differ from phone to phone, so consult your user manual as needed.
4.If the software resets did not restore your service, it's possible that the cellular radio has ceased functioning correctly. Contact your carrier for repair, replacement or exchange if it is still under warranty. Your carrier can advise you of the options you may have.
Apr 15, 2011 | Cell Phones
Not able to make or recieve calls
Hello
Check if there is network on your phone,if there isnt you may just have to go to a n area with clear network or maybe it is just a network problem
Oct 02, 2010 | Cell Phones
No service
  • Turn the device off and back on. Most service issues are due to old, timed-out registrations that have dropped you from the network. By power-cycling the phone, a new registration is acquired and signal should be restored.
  • Perform a Master Reset. If power-cycling did not restore your service, the problem may be due to a software issue. Doing a master reset will revert the software back to factory standards, restoring your service by removing bugs that may have developed over time. Generally this is done by pressing "Menu," "Settings," "Initial Setup" and "Master Reset." However, steps may vary from device to device so refer to your user manual for different steps if needed.
  • Perform a Master Clear. If the master reset did not restore your service, the software issue at work may be severe. In this case, it is necessary to completely wipe all information from the device and install a fresh copy of the operating system using the Master Clear function. Press "Menu," "Settings," "Initial Setup" and "Master Clear." Again, steps may differ from phone to phone, so consult your user manual as needed.
  • If the software resets did not restore your service, it's possible that the cellular radio has ceased functioning correctly. Contact your carrier for repair, replacement or exchange if it is still under warranty. Your carrier can advise you of the options you may have.
  • Sep 27, 2010 | Cell Phones
    Proper settings for the Honeywell thermostat T87K
    I'm going to answer your questions based on the way I THINK your system is setup.
    If anything isn't making sense, please feel free to ask.
    2> cycles per hour is for air handling only, if there isn't a call for heat, you may still want to move air in order to not have the space feel "stuffy", or develop a moisture issue.
    3> the cycles per hour to choose depends on alot of variables. Some of these include geographical location, type of construction, use of the structure (what is this building used for?)
    4>The high and low limits are for the target fluid temperatures for the boiler. The cycles per hour are for the air handler.
    Your installer should have setup these things for you, and been able to explain them to you in a reasonable manner.
    Hope this helps! Feel free to ask any more questions you need.
    Helping Hands Services
    _ Fairbanks, Alaska _
    Feb 11, 2010 | Heating & Cooling
    Initial setup to operate gps?
    you normally wouldnt have to but it is recommended to charge it. if it was tested before it was packaged, its possible it was in sleep mode instead of turned off..if its in sleep mode, it will drain the batteries over time. if its not starting, charge it for a few hours, then hold the power button untill it starts. if that does not work, try a hard reset.
    Jul 09, 2009 | Magellan Maestro 4250 GPS
    Changing the time on my Motorola Razr V3 phone
    you must first disable Autoupdate (turn it off) - go to settings>scroll to Initial Setup, (select this)>Time & Date (select this)>Autoupdate (set to OFF)>after you do this option will appear to change time to 12/24 hour....
    May 11, 2009 | Motorola Mobility RAZR V3c Cellular Phone
    How do I adjust date of my watch bought from GAP
    Here is the manual from GAP customer service.
    Dear gap.com Customer,
    Thank you for your email regarding the Sporty Printed Watch user
    instructions. Please accept our apologies that no directions were
    received with your order.
    The instructions are as follows:
    Button Functions:
    A. Light
    B. Mode
    C. Start
    D. Reset
    Standard Time Adjustment:
    1. To set the time, press the Mode button three times (The seconds and
    the word Tuesday should start flashing).
    2. If the seconds position shows less than 30 seconds, pressing the
    Start button will reset the seconds to 00. If the seconds position shows
    more than 30 seconds, pressing the Start button will reset the seconds
    to 00 and the minutes will increase by 1.
    3. Press the Reset button until the area you want to change starts
    flashing (i.e., second, minute, hour, day, month, and weekend. Press
    Start button once for per unit increment, press and hold for 3 seconds
    for speedy advance.
    4. At completion, press Mode button to resume standard time display.
    To reset the Alarm:
    Press the B: Mode button until you reach the alarm.
    Press the D: Restart button.
    Press the C: Restart button to get back to the time
    Sep 29, 2008 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
    V3m can't save picture
    tom2209 - you try resetting the entire mobile to see if that corrects the errors.
    Guest, - you can install the software that came with the phone.
    Mar 13, 2008 | Motorola Mobility RAZR V3m Cellular Phone
    I do not know how to set my clock on my razr after the time change last nite
    Settings
    Initial Setup
    Time and date
    • Turn AutoUpdate Off
    select and make the change
    Nov 04, 2007 | Motorola Mobility RAZR V3m Cellular Phone
    Intermatic EJ500C - Indoor Digital Wall Switch Timer - Astronomic Feature Logo
    15 people viewed this question
    Top Intermatic Electrical Supplies Experts
    Hippy_dd
    Gene Haynes
    Jay Finke
    Jay Finke
    Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
