Question about Kenwood eXcelon KDC-X769 CD Player
Kenwood kdc-x769.everything works on the deck just fine other than no sound at all-not even static. did a full and proper install into vehicle and cant get anything to come through the speakers-any help or insight as to where i can send it to be fixed or how to fix myself would be greatly appreciated-thanks for your time
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
You may want to check and make sure none of the speaker wires or speaker terminals are shorting out. it just takes one shorted speaker or speaker wire to shut off the entire audio.
Posted on Jul 14, 2010
I have a kenwood kdc bt43u and transferred it, with my amp and rear speakers, to an identical vehicle. It all works fine until i use bluetooth. sound only comes from the front factory fitted speakers
Not quite sure what you are saying here but I am going to take a stab. If I am filling in the gaps but are the rear speakers wireless? If this is the case then they are not paired with the speakers but with your receiver deck. You will need to pair the speakers as well before it will play through them.
Dec 21, 2014 | Kenwood Car Audio & Video
Kenwood KDC-319 CD Player Logo Problem with KDC-319 CD Player installed a kenwood kdc 319 in a 04 chevy malibu when i have car off i turn deck on an my cars dash board lights turn on Posted by A
I would start by disconnecting the radio and hooking it up right,the power should go through the ignition switch.So that when you turn the car off the radio will go off and to hear it on again you have to turn the key to accessory or start it.That might take care of a few of your problems.
Jun 25, 2012 | Kenwood KDC-319 CD Player
The fold down panel does not retract all the way when the unit is turned off
you may have a gear inside the deck that is out of position.
it probably needs to be taken apart and adjusted.
Oct 13, 2010 | Kenwood eXcelon KDC-X769 CD Player
When i turn the car on the control panel on the Kenwood excelon KDC-X769 jus starts on opening and closing but never stays opens
you may have a bad face position sensing lever inside the deck, or bad gears. it could even possibly be bad flexible cables.
Jun 20, 2010 | Kenwood eXcelon KDC-X769 CD Player
I just bought a Kenwood KDC-MP438U I installed all the wires right, power is to the deck because it accepts a cd. the deck face doesn't light up. I called in at Kenwood and they had me test it directly to...
Check your Ground Wire inside the Truck and Check the Illumination Wire. I Think on Kenwood the Illumination Wire goes with the Power Wire. If they still will not work, You might want to get a Wiring Harness from Schoche.com Please Rate My Response! Thanks!
Jan 30, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Kenwood deck reads protect and won't function
you have one of your speaker wires shorted out to the body of the car somewhere, or the speakers that you installed are bad. That is the only two reasons it will go into protect. Correct the problem, then reset the deck - it should work fine.
Kenwood builds this feature in to protect the outputs - so they dont burn up in the case of shorted speakers or wiring.
Jan 16, 2009 | Kenwood KDC-MP235 CD Player
Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Jun 09, 2008 | Kenwood KDC -X815
Toc error
i have had the same deck for four years and installed and removed from 4 different vehicles. the deck has been through some stuff lets put it that way. mine does the same thing as yours, i have found that you just keep ejecting the disk untill it reads. usually only takes a couple times and then mine works just fine.
May 26, 2008 | Kenwood KDC-MP828 CD Player
Kenwood excelon kdc-x815 display screen no power
recently bought a kenwood kdc-815 car radio from a swamp met. bought it with no security code need security code
Apr 08, 2008 | Kenwood KDC -X815
No sound after installation on a kenwood kdc 30-11
wellllll the most common cause of no sound it that there is a factory amplifier in the vehicle that is not turning on with the radio.. this is done by using the remote turn on wire from the aftermarket deck. or it could be a blown speaker that is shorting out the amp in the deck
Feb 19, 2008 | Kenwood KDC-MP235 CD Player
Kenwood eXcelon KDC-X769 CD Player Logo
109 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
