Question about Whirlpool Duet GHW9150P Front Load Washer
Half way thru wash, it stops and flashes F20 - Whirlpool Duet GHW9150P Front Load Washer
  • 713 Answers
Hi, here is what you do. First unplug washer. Then take top cover off. You will see a 4" cup with a small tub right by it. The tub is clogged up. Blow hard into the small tub. This will unclog it and your good to go! Replace top and plug in. There your a repairman!
Posted on Jul 13, 2010
Washer will not complete cycle sends F20 code
he f20 (or fh) error code on a Whirlpool Front Load Washer is an indication of a water supply issue. To remove the f20 error code from the display panel, press Pause/Cancel 2 times. If that did not clear the error code, see below for what may be wrong
heres a link...https://removeandreplace.com/2016/01/12/whirlpool-washer-error-code-f20-troubleshooting-front-load-washing-machine/
Jul 12, 2018 | Washing Machines
Hi i have a indesit washing machine and it keeps stopping during a cycle and flashing F20 do you know what might be wrong it is not draining water
Find out what the F2 0 signifies. But if it is not draining water, clearly the pump is not functioning. Find out why.
Sep 02, 2017 | Indesit Washing Machines
F-20????
Check for any error codes in the Estimated Time Remaining display. The code "F20" indicates a water inlet problem. Press the Stop button twice to end the cycle and check that the faucets are turned on fully. Take a look at the inlet hoses. Close the valves and unscrew them. Look for any clogging on the screen and clear it.
May 17, 2010 | Kenmore HE2 Plus Front Load Washer
Washing machine stops half way thru and flashes code LD?
Long Drain
Ld flashes when the water level does not change after the drain
pump is on.
Is the drain hose clogged?
Is the drain hose height greater than 96′?
Is the pump running? If not, see TEST #7, page 13.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 06, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
When the washer is washing a code F20 will flash
take the top of the washer off there is a book in there that will tell you what f-20 is
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
MAYTAG 3000 SERIES JUST RECEIVED AN F20 CODE. WHAT DOES F20 MEAN? THE MECHINE RAN FOR 10 WASHING THE STARTED STOPPING ABOUT 10 MIN IN TO THE CYCLE WITH F-20 FLASHING.
need the correct model # and ser # _ _ _ 3000 _ _ _ _ this tell us age and and fault codes . now inside the machine / you will find a tec sheet with the codes . this may be quicker .. mm
Dec 02, 2009 | Dishwashers
My washer is flashing F20 what does that mean stopped during cycle and flashed f20
F20 means there is an electrical problem.
Click on this link to go to the manual and look at page 21.
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0606184.pdf
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Kenmore Elite 45986 Front Load Washer
When washing stops and flashes f20
That code means "No water or Insufficient water supply" Check the water supply valve, the fill hose screen for debris... Good luck let me know if that solved it..
May 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Whirlpool Duet GHW9150P Front Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
