Question about Husqvarna Forest & Garden 125c 17" Curvgastrimmer
How do i remove the trimmer head to replace it with a pivotrim head
How to remove the pivotrim head from a grass trimmer
There are usually flats above the head to use a special flat wrench to hold it with.
Or take the engine off and hold the shaft very carefully not to scar it
Jun 04, 2014 | Rino Tuff Pivotrim String Trimmer Head for...
Replace trimmer head
Most trimmer heads unscrew clockwise. Watch the video which shows how to remove most trimmer heads.
How to Replace Trimmer Head
May 30, 2014 | Tanaka Trimmers Tbc-230sf String Line...
Weedeater
According to Pivotrim, it will fit your trimmer, BUT...
I can see your dilemma here.
Here is a link to the installation tips page for your type of trimmer: http://www.pivotrimhelp.com/Installation/Default.aspx
It is recommended for your model to use "Installation Method 3", here is the instructional video:
Now, It does look like the threaded, exposed end is a bit short. From personal experience with this model of trimmer, I found that the entire shaft would slip out overtime form the motor housing. With an allan key, you can loosen the joint where the shaft meets the motor housing near the throttle control. When loosened ensure that the shaft is as far up as it can go, then tighten again.
Hope this helps.
Jul 08, 2013 | Garden
I have a new Pope Renegade 26cc Line Trimmer. Started it up but the cutting line bump feed would not operate. Removed the spool from the spring head and the line was tangled. I removed the tangled line...
Hi John, I have exactly the same problem. I can't go further than about 5 feet before I need new line. I can't help, but I thought you might like to know you are not the only one having problems with this trimmer!!
Sep 09, 2011 | Toro Garden
I want to remove the head on my Craftsman 17" 25cc
If it is like other trimmers there is a hole on the top side of the head put a small screwdriver in that hole it will stop the head from turning unscrew the head counterclock wise.
Dec 12, 2017 | Craftsman 25cc Gas Line Trimmer
How do I remove line head to so as to fit a pivotrim head on a 31cc 17" craftsman weedwacker
The best solution is to get the owners manual so you have complete information. Go to www.searspartsdirect.com and have your model number ready.
Jul 29, 2011 | Craftsman 25cc Gas Line Trimmer
How do I remove the spoolhead so as to afix the pivotrim head
I installed the Pivo trim head yesterday. The info that came with the unit will show you how to install it on ANY Weed Eater Unit. Also they have videos on their web site at: https://pivotrim.com/
Look on the end of the shaft of your weed eater at the head. Mine was a 25cc Poulan/weed eater SST45 and it has a hole that you need to stick a HEX KEY in so the shaft does not move when you try to remove it. ALSO it has a BACKWARDS THREAD!!! So "Right is NOT Tight." Left is to tighten and turn towards the right to get the head to unscrew so you can put on the Pivotrim Head. Also you can use ANY Weed Eater line on the unit. As I tried several different lines and found different uses for different lines. Such as edging and trimming against fences. Best after Market Weed Eater head I have EVER used. :-)
Enjoy! :-D
Jul 28, 2011 | Craftsman 25cc Gas Line Trimmer
How do iremove trimmer head weedeater fl20
It depends on your model. You can visit the PIVOTRIM website and they show how to install their head on most units which includes how to take your old one off. Their website is http://www.pivotrim.com
Otherwise you need to look at your operators manual or call the manufacturer.
Jun 14, 2009 | Garden
Husqvarna Forest & Garden 125c 17" Curvgastrimmer Logo
52 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
