Question about Dell OptiPlex GX520 PC Desktop
Dell optiplex Does notb Run. Switch Button is blinking. Powerb Supply is ok. Ram ok. I use Another good power supply but same problem Power Button blinking. Whats the solution.
    Scholar:
  • 181 Answers
The next thing to check is your Motherboard. Remove all devices (hard disk, cards, memory, etc) just the motherboard connected to the power supply, just to see if the motherboard is working right. Your should be hearing a beep sound indicating that the board is alive. If yes, you may reinstall the rest of the devices you removed.If no, replace motherboard or processor.
Posted on Sep 13, 2010
Have a Dell Optiplex 740 desktop. Power button is lit solid orange. No diagnostic lights on. Fans still blowing. Replaced power supply unit still nothing. HELP!!!!!
before replacing main board,try replacing individual hardwares like ram,processor and if still not working,try resetting the bios by alternating the jumper on the labelled CLR CMOS
good luck
Mar 28, 2013 | Dell OptiPlex 740 PC Desktop
My dell optiplex light is solid yellow
That usually means the switch on the power supply has been moved to 220v vs 110v. The switch is located just above where the power cord plugs in.
Aug 31, 2012 | Dell OptiPlex GX620 PC Desktop
Power led blinking
1) the function can be the power supply box ffaulty, see if the fan are RUN, and test the power supply for +5VDC, otherwise is faulty the p.supply box
2) However you must RUN the software from DELL coming with the computer, or contact DELL for chat ONLINE,
God bless you
Jun 19, 2012 | Dell OptiPlex GX520 PC Desktop
Blinking amber power button light on Optiplex 990
It seems you have a problem with your Processor regulator that is why your computer sending an amber message.
This problem always happens to Dell Optiplex mostly and there is no solution for this except replacing your Motherboard.
To verify this problem unplug yellow (2 yellow and 2 black cables) cables near the processor and then try to turn it on when you see the fan processor can run smoothly and the power light getting green that is the sign that your processor regulator having some sort of problem.
Hope this will answer your problem
Apr 30, 2012 | Dell OptiPlex 990 SFF 1 x Core i7 2600 34...
I got dell optiplex 755 desktop computer in the power supply unit at the back there is a small button and a green light what are these for??
It help diagnose problems with your computer
A solid green light means the computer is operating normally.
A solid yellow:- the power is operating fine but your computer not processing data. This could mean there is a problem with the CPU or another component on the motherboard.
A blinking yellow light: power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode
Jan 29, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
Yellow light on the power button of my Dell Optiplex GX520. I've tried: 1. Replaceing the power supply 2. Replacing the CMOS battery 3. Removing and reinstalling the RAM memory. 4. Replacing the...
A solid orblinking Amber power button indicates a voltage problem. This can be caused bya defective power supply or a defective motherboard. Just to make sure thatnothing else is causing the problem, remove any PCI cards like modem, videocard, sound card, etc... Remove the memory modules and disconnect cables toCD/DVD drives. Look at the USB ports to see if any are damaged.
Sep 18, 2011 | Dell OptiPlex GX520 PC Desktop
I have DELL Optiplex GX 280 .. when i plug the computer on power .. that turn on automatically then have very loud fan noise , no blinking lights and the processor work good on another motherboard and ram...
Hi, Thanks for using fixya.
I have the same computer with the same problem. I changed the power supply that cured it for me, I hope it does the same for you.
Terry
Feb 15, 2011 | Dell Optiplex GX280 (99301) Motherboard
Dell optiplex 330 flashing orange on the power botton
Try to clean the RAM and place it again in the motherboard.
May 31, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Dell optiplex 270 startup
sounds like power supply failure. You can try removing all of the ram and pressing the power button again. If nothing happens, its either a bad power supply or a bad motherboard.
May 22, 2010 | Dell OptiPlex GX270 PC Desktop
Dell? OptiPlex? SX280 blinking yellow what is that
blinking yellow light on the power button of a Dell system is a possible power supply issue. press the eject button on the dvd drive while the power button flashes yellow light. if the disc trays wont come out, you need to replace the power supply. hope it helps. good day.
Jan 07, 2010 | Dell OptiPlex SX280 PC Desktop
Dell OptiPlex GX520 PC Desktop Logo
181 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
