Question about Hotpoint SY36 Style Line Stainless Steel Electric Single Oven
Cooling fan seems to be making a very loud noise , is it easy to replace
    President:
  • 1,891 Answers
On a scale of 1 to 10 / it's a ( 7 ) / takes about 1 hr . and helper for wall oven . .
Posted on Jul 15, 2010
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Dec 12, 2010 | AEG D4101-4 Electric Double Oven
Noise
It will be the external cooling fan that is causing the noise.
Probably worn beaqring or broken fan blade.
Normally, the only solution is to replace the fan motor.
It is located at the top of the oven, usually at the rear, but not in every case.
Please rate my solution.
Thankyou.
Jan 23, 2010 | Zanussi Ovens
Our fan seems to make a loud rattling noise
Hello, Happy new year ! Now for the oven problem. Do you know if it is the convection fan in the oven cavity or the cooling fan in the cabinet ? If it is the conv. fan, it's quite likely just a loose fan blade. remove the rack's and then the cover of the fan and you should be able to inspect the fan blade and more specifically the retaining nut at the center. You can tighten it if loose,( carefully they tend to bend easy ) but be sure the fan itself isn't bent or damaged in some fashion. If that doesn't solve the problem let me know I'll try to direct you to the cooling fan, however it is much more involved and I typically suggest a pro tech. Hope this help's, good luck and thank's for visiting "fixya" today. Macmarkus :)
Jan 01, 2010 | Zanussi Ovens
Fan noise
It is a cooling fan, and, yes it can be replaced.
Thanks.
Nov 22, 2009 | GE Ovens
Turbo Chef hi speed oven prblem with 2004 model very loud fan
is this a c3 or a tornado oven.there are afew causes for that type of noise but are diffrent for each type,regards les
May 08, 2009 | TurboChef C3 Single Oven
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
I have an electrolux icon double wall oven. I turned on the self-clean function for 3hrs and it making a very loud noise during the cleaning process. Is that normal?
yes, if the humming is not the loud sound then the fan may need some lubrication or if it is tripping the circuit it will need replacing , but if it seems like it is a viberating noise from the fan , then it could be that its bearings are bad , but the whole fan motor would still need to be replaced , but if it sounds like it just may be a loose fan motor , then tightening up the screws on the motor would stop the vibrating sound and or the fan blades from scraping metal( another sound you may be hearing )
Dec 24, 2008 | Electrolux ICON 30 in. Double Wall Oven
Odd loud fan type noise
what you are describing is the cooling fan. That fan will come on to keep the electronic control panel cool. It is normal for tat to come on even if your done with the oven. I dont think is should be as loud as you describe. I would try the oven again and if it is still loud I would call for service because it is new. That fan will also come on when you use the self clean cycle.
Jul 25, 2007 | Frigidaire PLEB30T9DC Electric Double Oven
Hotpoint SY36 Style Line Stainless Steel Electric Single Oven Logo
206 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
 Fix Your Board
Fix Your Board
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
