Question about LG LP1200DXR Portable Air Conditioner
It shows the FL error telling me the water collection tank needs to be emptied. But when I do what the manual says (open the lid in the back) there is nothing in there (not even a drop of water) The A/C continues beeping and giving that error. What can I do? Why don't you put the money plan first instead of making me lose time???????????????? Go to hell!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    New Friend:
    Problem Solver:
Tip the zircon back a little bit and water will pour our. I did this because i had the same problem. This solves it
Posted on Dec 23, 2014
2 Suggested Answers
  • 52 Answers
SOURCE: why does the water collection tank on my LG
because the unit is removing a lot of humidity from the air into the form of condensation.
Posted on Jun 14, 2009
FL is what it reads on display A/C doesn't work
The water collection tank is full and needs to be emptied.
Jul 07, 2017 | Washing Machines
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Why does it turn off and on
Fl means that the water collection tank is full and needs to be emptied. The unit will turn off if it's full.
I could not find the installation manual for your exact model number, but here's one that's similar enough:
http://www.lg.com/us/support-product/lg-LP1111WXR#
It is PDF filetype, so if you can't view it, you need to download and install Adobe Reader on your computer:
You can get the free download here:
http://get.adobe.com/reader/
Sep 05, 2012 | LG LP0910WNR Air Conditioner
SAYS COFFE READY PUSH LARGE CUP AND A COUPLE OF DROPS COME OUT THAN SAYS FILL AND PUSH STEAM HAVE DONE AND REDONE SEVERAL TIMES STILL NOT GETTING A CUP OF COFFEE TOOK TANK OUT AND CHECKED FOR FLOTATION IT...
Hello.
1 Perform the initial setup on the coffee maker. Make sure the coffee maker is not plugged in. Slide the empty funnel into the funnel guides, fill the decanter with cold water, open the lid and pour water from the decanter into the brewer, put the decanter back on the base, then close the lid and wait three minutes for the internal tank to partially fill. Open the lid, fill the decanter with cold water again, and once more pour the water directly into the brewer. Put the decanter back on the base and wait for water to flow out of the funnel and into the decanter. Once it has stopped flowing, pour out any water that is in the decanted and plug in the coffee maker. Press the on switch to turn the coffee maker on and heat up the water in the tank.
2 Ensure the lid is completely closed. If the lid is open, the Bunn coffee maker will not brew coffee.
3 Check the see how much water is in the water tank. The Bunn coffee maker will not begin brewing coffee if less than 20 ounces (4 cups) of water is present in the water reservoir tank.
4 Delime the coffee maker. Unplug the coffee brewer and allow it to cool down. Remove the sprayhead by turning it by hand and set it aside. Insert the flexible deliming tool into the sprayhead tube until all but two inches are showing. You may need to twist and force the tool to go in. Slide the tool in and out several times to loosen lime buildup.
Check the sprayhead for lime buildup. If there are flakes of minerals, they can be removed with a toothpick. Scrub the sprayhead with soap and water. Rinse the sprayhead with water and replace it in the coffee maker. Pour water into the water tank and turn the coffee maker on, allowing water to run through without making any coffee. This will flush any lime fragments through the system. Empty the decanter
Thanks.
Sep 18, 2011 | Jura Capresso Impressa S90 Espresso...
How to fix E1 error code?
If it's a Delonghi Portable AC unit, E1 indicates that the water collection tank needs to be emptied.
If I knew which brand and the model number of what you had, I could be more specific.
Thanks for choosing FixYa.
Sep 11, 2011 | Heating & Cooling
It is saying FE with a triangle error, and won't turn on???
Actually, what you're seeing if "FL". It indicates that the water collection tank is full and needs to be emptied. Once that's accomplished the unit will operate again, as it should. Be sure to turn the unit OFF & unplug it, before draining the tank.
Hope this helped you and thanks for choosing FixYa.
Aug 27, 2011 | DeLonghi PACA110 Portable Air Conditioner
Lg portable air conditioner shuts off and has an E1 error.
I think what you may be seeing FL , instead of E1. FL indicates that the water collection tank is full and needs to be emptied. That would coincide with the unit shutting OFF and not being able to restart it.
Turn the unit OFF and Unplug it, before draining the tank. Once the tank is drained and the unit is restarted it will revert back to cool at 77 degrees F. You can then restet the temperature to what you desire.
I hope this helps you and thanks for choosing FixYa.
Jul 25, 2011 | Heating & Cooling
Can you you tell me why there is a flashing red light on the coffee machine
Descaling light:
• on and fl ashing: signals the need to perform a descaling cycle
Machine ready light:
• permanently on: signals that the machine is ready for use.
• on and fl ashing: signals that the machine is warming up.
Alarm light:
• permanently on : signals the machine is out of coffee, the water tank is
empty, the drip tray is full or the dregdrawer is full (in this case, also empty
the coffee grounds drawer in order to prevent failures).
• on and fl ashing slowly: signals that the brew group is not inserted, the
dregdrawer is not inserted the coffee bean hopper lid is not on, the service
door is open or the steam/hot water knob is not correctly turned to the
desired position.
• on and quickly fl ashing: signals the need to prime the water circuit.
Jan 13, 2011 | Saeco Odea Go
I have a whirlpool top loader with calypsoTM wash motion. The machine showed Off Balance I had to start over them the machine showed ''FL'' over Fill. I turned the water off and have tryed to get the...
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Feb 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Aeg lavamat error code E20. Machine will not progress to spin cycle
This means that there is an issue with pumping water out from the machine.
Possible reasons:
-The hose for water outlet is bent
-The water outlet is more than 1metre above the bottom of the machine.
-The emptying pump is clogged up
-If connected to a waterlock, the waterlock may be clogged up.
If the emptying pump is clogged up, the solution is to empty the machine manually. First turn the machine off and disconnect the electricity. There is a small lid on the bottom right corner of the machine. Inside you will find a small hose. Ready a small box for collecting the water. Warning: The water may be hot. Allow the water some time to cool down. Remove the plug from the hose (screw it out at first, then pull the rest out). You may have to empty it in a couple of sessions. Just put the plug back in if the box gets full of water. repeat until no more water flows out. Put the plug back in. Now put a towel underneath the front of the machine for collecting water that flows out when you open the lid for the pump. You can open the lid of the emptying pump by turning it counter clockwise. It is right next to the small hose you just used. Pull the lid out, and remove what is clogging up the pump. Before you slide the lid back in, you should check that the pump goes around. You can do this with a pen and a flashlight. Use the pen to move the pump around. It is normal for it to move in "bursts" (that it's not revolving smoothly). Slide the lid back into the tracks on the inside of the housing of the pump, and close it. Now you may reconnect the electricity, and the machine should work._1923.jpg_1924.jpg
Oct 27, 2008 | AEG Washing Machines
LG LP1200DXR Portable Air Conditioner Logo
1,677 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
