Question about Craftsman 20 hp 42 in. Deck Yard Tractor
My craftsman 917.27682 starts great but the back wheels are locked. I know the freewheel lever needs to be disengaged but that still doesn't make a difference. any suggestions???
  • 86 Answers
SOURCE: replace drive belt Craftsman 917-255572
First you have to remove the deck,then you may have to remove belt guards to install new one,then reinstall the deck
Posted on May 12, 2009
  • 57 Answers
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
Posted on May 19, 2009
  • 376 Answers
SOURCE: Craftsman 20hp tractor starts with mower engaged.
OK. You have one of two problems, or maybe a combination of the two.lol. Either the clutch cable that runs from the lever to the deck is frozen, or most likely, the pivot point on the idler arm on the deck is rusted up and is not disengaging. Spray some penatrating oil at the base of the bracket the idler pulley is mounted on (pivot point) while working it back an forth until is loosens up. There is also a spring that is hooked to the idler arm and to a slot in the middle toward the front of the deck to pull the arm forward when the blades are disengaged. Make sure that is in place also.
Posted on Jun 10, 2009
AUTODOC01
  • 216 Answers
SOURCE: My Craftsman LT 1000, model No 917272761 will not
you taliking about the relase at the rear you pull out to roll it? it just connects at the top of the transaxel you can go to searsparts.com type in your model# for exploded veiw of the lever ? hope this helps
Posted on Aug 31, 2009
  • 110 Answers
SOURCE: I have a 17 HP
There are blade brakes, one on each blade pulley. You will need to check that the brakes are in good working order and that the springs holding them against the pulleys are in place. Also there is a spring to return the idler pulley to the neutral position. The spring could be broken or the idler pivot rusted not allowing it to return to fully neutral position. This should get you going down the right track. Hope this helps; please vote yes. Thank you.
Posted on Dec 06, 2010
Craftsman 56" lawn tractor auto trans dose not drive forward or revers. tryed purging trans no go checked engagment rod ok, belt seems good. I can push the mower by hand as if the trans were not connected...
somehow did the little freewheel lever get pulled in the rear of the tractor to disengage transmission?..usually out is disengage and in is engaged. look around the back panel behind the rear axle for a small lever you can pull or push in.
Aug 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Where is the freewheel lever located on the jazzy 1113?
Original Jazzy Select has push-down levers on each side behind powered wheels. These manually disengage the brakes on each motor individually. They are about 6 inches long and push down an inch or so. I don;t know about other more current models, The 2 smaller wires to each motor disengage the brake when given power (24 volt, I think). The 2 larger wires run the motor.
Jun 17, 2012 | Pride Jazzy 1113 ATS Indoor Power...
I have an older version od the 1121 but cannot find the lever for freewheel. I know where it is on a modern one
I believe the older versions had a release lever and cable system at the rear center. This was a 2 step, 2 handed on your knees process to release the lock on lever with your left hand and pull out and turn the lever with your right hand. This pulled on the cables to both motors to disengage the freewheel levers
Oct 12, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Pride celebrity 4 wheel wont turn on
Hi
Please Check that your Freewheel Lever is Fully in Position as if is Slightly out of Position it will Not Work,
Gerry.
Nov 02, 2009 | Pride Celebrity X 4-Wheel Electric Scooter...
Craftsman 15.5hp 42'' changed hydrostatic fluid with mobile 1 synthetic 15w50 and now the wheels will not rotate at all. Checked everything belts on right pulley turning on top of tranny, disengage for...
Purge the transaxle by pulling the freewheel lever at the back of the transaxle.With the lever in the freewheel position run the engine full speed with clutch out,work the forward/reverse control back and forth 10 times and then try it.Also make sure that if you had the wheels of that you didn't lose a wheel key.
Aug 15, 2009 | Craftsman Garden
The scooter rar wheels locked up nothing moves
hi, if the freewheel lever is jammed which is located on the drive motor, take the rear cover off and make sure the lever is not bent,
you will see how the freewheel lever is mounted under normally a rubber cover on the side of the electric motor ,
Let me know
May 16, 2009 | Pride Mobility Victory 3 Wheel Electric...
Rear wheels will not turn. Worked fine when stored for the winter
Craftsman-Husky...same tractors-built in the same factory. I also had a problem with the hydrostatic transmission not providing power to the rear wheels. Here's what Sears told me:
(1) Check to make sure the drive belt is tight both under the engine-and the tranny.
(2) Air can get into the hydrostatic transmissions-especially during shipping (new mower) and storage.
So.....
Pull your freewheel pin out to disengage the tranny-then push the mower both forward and then backwards for 50' or so. Then push the freewheel pin back in and start the mower. If the transmission then works-drive forward-then backward-then forward repeating the cycle about 4 times. Drive about 50' in each direction. This should purge the air from the treansmission.
Mar 20, 2009 | Craftsman Garden
Not running - full battery
hi look up www.americanmobilityscooters.com in Jacksonville FI 32211 ...Cheers
Apr 05, 2017 | Echo 3 TE SL7 3 New Electric Scooter by...
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
