Question about Dell 924 All-in-One InkJet Printer
It won't print and i have a code 1203 i have removed the carr many time but nothing
    Guru:
  • 366 Answers
Please 1. Disconnect the printer or at least be sure it is turned off.
2. I'd do both and reinstall the CD software program that came with
the printer.
3. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps.
Posted on Jul 18, 2010
Hi, i'm getting error message 1203 on the printer and we've lost the user's manual. Can you tell me what this is?
Error 1203 is a very interesting error code. Here is what I found out about error 1203
Error 1203 is a very interesting cartridge error. It means your cartridges overflow even from brand new cartridges after a several prints or right after you refilled the cartridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
I use the lint free cloth(coffee filter work great) with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
Then before you print anything, you should run aligned the cartridges a couple times then run clean cartridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of lint free cloth(coffee filter work great on those holder contact panel.
Article on refilling Dell ink cartridges
Rick
Sep 10, 2011 | Dell 926 All-In-One InkJet Printer
The printer read Cartridte error 1203 I am reading the manuel but I do not understand how to fix it to print. I do not have it connected to the computer I just want to make copies.
Are you using Dell Series 9 ink cartridges?
Error 1203 is a very interesting cartridge error. It means your cartridges overflow even from brand new cartridges after a several prints or right after you refilled the cat ridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
Rick
May 30, 2011 | Dell 926 All-In-One InkJet Printer
LEXMARK X5450 CODE 1203 ?
This is a cartridge alignment error. Follow the steps below to fix the problem.
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
2 Disconnect the power cord from the electrical outlet.
3 Reconnect the power cord to the electrical outlet.
4 If the button is not lit, press .
5 Reinsert the black (or photo) print cartridge.
Jun 04, 2010 | Lexmark C533DN InkJet Printer
On the printer screen it say's error #1203
Error code 1203 means the catridges overflow even it is new or after you refilled them.
Solution:
Use tissue with a few drops of water to dampen and clean off those contact on the holder.
Before printing anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look.
Be sure not to leave any debris of tissue on those holder contact panel.
To reset the error code, disconnect the power cord from the wall. Also remove the power brick from the back of the printer for 60 seconds. Then connect everything again.
Hope it helpes.
Mar 25, 2010 | Dell 946 All-In-One InkJet Printer
Error 1203 is a very interesting cartridge error. It means your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Be sure not to leave any debris of klennex on those holder contact panel.
Hope this helps and please feel free to rate me
Sep 12, 2009 | Dell 942 All-In-One InkJet Printer
Dell Printer 926 Error 1203 "Print Head Short"
Error code 1203 means that you have a print head short error. The way to fix this is to:
1) Clean the contacts on the cartridge w/ a damp cloth. Only do it in one direction so that you're not smearing ink all over the contacts!
2) Disconnect and then reconnect the power cord from the wall and from the back of the printer. Wait about 30 seconds, and then plug everything back in.
If this doesn't work, you may need to replace the ink cartridges...you can always try it one more time just to be sure
Jan 09, 2009 | Dell 924 All-in-One InkJet Printer
Lexmark x4270 error code#1203 want print
Please visit this below mentioned link to solve your problem:
Error Code 1203
Thank you
Dec 07, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error message 1203
This link should have the answer for you.
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
Jul 27, 2008 | Dell 924 All-in-One InkJet Printer
Error 1203
You can try testing your Printer with another Print Cartridge and if the error message repeats, you should contact Service Center as then there would be a Hardware Problem.
Jul 15, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Dell 924 All-in-One InkJet Printer Logo
21 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
