Question about Euro-Pro 9105 Computerized Sewing Machine
Bobbin casing to please help me I received a machine from a friend and the bobbin cover is missing. will this keep the bobbin from doing right ? I have tried to use it by putting a piece of cardboard over it but it still gets tangled. I am going to order a cover for the bobbin case.
  • 980 Answers
Wise not to use it until you have the proper slide plate
Posted on Jul 14, 2010
My class 66 singer bobbin has no notches to put the thread in... i have NO idea how to thread it. i have no problem winding, its just the sewing part. please help!!!
It sounds as the the actual bobbin CASE is missing from the machine. This is the part under the chrome slide cover that has a "dish " into which you drop your bobbin. The edge of the "dish" has a slot for the thread to go in and a slot where the thread lies after it has gone under the spring on the outside of the "dish". If it is missing I'm afraid you will need to source one before you can hope to sew.
Jan 12, 2016 | Singer Sewing Machines
Ce-200
Is the Bobbin the right size for the machine? That may keep the bobbin case from latching properly, causing this phenomenon. Shuttle latched in properly? Machine cleaned and oiled per the manual? Make sure bobbin is wound straight and correctly... Post with results or follow up questions
Dec 30, 2013 | White Sewing 2037 Mechanical Sewing...
I have a Bernina Activa 230 and my bobbin case is stuck in the machine and it wont come out, Someone Please help me what do I do?
can you unlatch the ring cover device? there is a little release lever on the left just inside the bobbin area which secures a hinged silver square called hook race cover, if you unlatch this, flop the cover forward, then the bobbin case and shuttle should all come out as well.
Nov 02, 2011 | Bernina Activa 130
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
I have a 15212 model sewing machine & have hardly used it. When sewing the other day a few stitches went out of the fabric and got stuck. I opened the shuttle assembly, cleared the tangled thread and...
Sorry to say but one of your steps is incorrect. Look at it again, take a deep breath and gom
over everything slooowly. If this really doesn't work then Im afraid it's a technician you need :) .
Apr 27, 2017 | Kenmore 15202 Mechanical Sewing Machine
Want pick up my bobbin
re-thread the top thread
when putting in the bobbin, make sure you put it in right,
hold the bobbin between you thumb and first finger of your right hand when you pull the thread with left hand it should rotate the bobbin counter clockwise.
If you run your machine all day you need to clean under the bobbin case,
Take the cover plate off, take out the bobbin case and clean under, i take a q-tip with machine oil and rub around the inside of the metal case and around the bobbin case,
replace the plastic bobbin case making sure it's in right, turn the hand wheel by hand, the case should stay still and the inside will move, the needle should not hit anything
put all back together and try again
if the bobbin turns clockwise you are going to have problems
if this helps please rate it
thanks,
good luck
moni
May 09, 2009 | White Sewing White 4400 Computerized...
Bobbin tension part missing
Buy a new bobbin case. It is the fastest,easiest way to fix the problem.
sewman7
Aug 28, 2008 | Singer 3116 Simple
Can't get the bobbin thread to raise
i have a singer inspiration my needle is hitting the bobbin case and needle keeps on breaking not picking up the thread . how can i fix the bobbin case. help
Mar 16, 2008 | Sewing Machines
HELP ASAP!
The bobbin case is in the wrong position to lock into the shuttle holder.Try instead of holding the the release lever of the bobbin case open, instead position the bobbin case finger to the up position and insert the bobbin case by pushing it in with your thumb. You should feel or hear it snap into position. You may have to rotate it slightly to get the finger in the proper position.
Nov 17, 2007 | Brother XL-5340 Mechanical Sewing Machine
Euro-Pro 9105 Computerized Sewing Machine Logo
90 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
