Question about GE WBSE2090A Top Load Washer
Washer overflowed during wash cycle - GE WBSE2090A Top Load Washer
  • 713 Answers
Hi, The first thing to check is the pressure switch hose. It goes from the pressure switch in the control console down to the airdome on the tub.
If it gets pulled loose, gets a hole in it, or gets clogged with lint or soap scum, the pressure switch will never sense the water level and turn the water valve off.
If the hose is ok, then you probably have a failed pressure switch.
Posted on Jul 13, 2010
Frigidarie Stackable Washer and Dryer leak
Check the Drain Tube, Check the Screen. When it gets to the FIRST Spin Cycle, Check the Water Level inside the Drum and see if it is Completely Draining... There is a Water Level Switch that should not be allowing it to Overflow so you may have an issue there... But first check for a Blockage
Aug 07, 2014 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool HFW95HEXW. During the Clean Washer cycle, water trickles down the front of the washer and pools in the pedestal drawer. The amount of water is small, but this happens during every Clean Washer...
YOUR WATER MAY BE OVERFLOWING A BIT AT THE TOP, JUST UNDER THE MACHINE'S COVER.
A SENIOR LADY FRIEND HAD SIMILAR SITUATION
WE TILTED UP THE TOP ON HER AUTOMATIC WASHER AND DISCOVERED THERE WAS A LARGE BUILD UP OF LIME, LINT , OLDE SOAP AND SOFTENER .
WATER GOING INTO THESE AUTOMATIC WASHING MACHINE IS OPEN TO THE AIR AND NOT CLOSED IN.
THIS HARDENED MESS WAS INTERFERING THE WATER FLOW, CAUSING SOME WATER TO RUN DOWN ONTO THE FLOOR.
Feb 09, 2018 | Whirlpool WFW95HEX Washer
The water drains too fast and overflows
Here is a tip that will help you with that problem...
Changing or Upgrading your Old Washing Machine
http://www.fixya.com/support/r4696582-changing_or_upgrading_old_washing_machin
heatman101
May 14, 2010 | Kenmore 23822 Top Load Washer
Small puddle of water underneath washer when wash cycle was completed.
That could be 1 of a couple things.
1) During the agitate cycle... some water could've made it out of tub.
2) Possible Tub Crack (or overflow line)
3) Check your inlet lines
I would run it again watching it very carefully to determine if any of these are the problem.
Dec 02, 2009 | Whirlpool LTE5243D Top Load Stacked...
Kenmore washer leaking during rinse cycle
Your air vent in your drain line is stopped up in your plumbing. Your washer is fine.
Jul 16, 2009 | Whirlpool WTW6400SW Top Load Washer
Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
I manually put water in my washer; water stuck inside
drain hose kinked or belt off pump . lower drain hose to floor if empties the pump is the problem
Apr 17, 2009 | Whirlpool Washing Machines
Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Whirlpool washer overflow during wash cycle
What you can try is to get the machine empty and remove the hose that connects the pressure hose to the switch and blow air through it to make sure it is clear, then tap on the nozzle where the hose connects on the switch to make sure it is also clear.
Oct 16, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
GE WBSE2090A Top Load Washer Logo
56 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
