Question about Sony KV-32V65 TV
TV does not power up. all we get is a red blinking led. Is there a fuse or something else simple to check?
    Scholar:
  • 41 Answers
It seems that the TV has an internal malfunction. The TV requires service.
Please contact the nearest Sony authorized service center to get it serviced.
Posted on Jul 13, 2010
Kdfe60a20 6 blink
Yes the power supply board is notorious for blowing caps and tv repair kits .com has a good DIY kit for this problem.
Oct 08, 2012 | Sony KDFE60A20 60" LCD HDTV
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Will not power up
What is the make and model of your TV?
Do you have a blinking LED which shows and error code.
Unplug from power for about 20 min to reset and see if powers on then. If there is no blinking light or sign of power it is most likely a simple fuse, or a power board.
For more info or general TV parts Pricing Check
www.RNS-Systems.com
Oct 14, 2009 | Soyo DYLT032D 32 in. LCD Television
Panasonic plasma hdtv will not power on--no blinking LED, simply no LED. Other objects plugged into same surge protector are fine; no evidence or suggestion of a power surge.
The power supply board itself maybe the main problem inside the TV. Or, it maybe something simple like a blown fuse. Replacement fuses can be found at Radio Shack or some other electronic supply store.
If it turns out the TV keeps blowing fuses, the main power supply may need to be replaced. You can find replacements at a good price at Shopjimmy.com
Sep 12, 2009 | Panasonic TH-42PX60U Television
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
http://servicemanuals.vstore.ca/
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Red light came on tv , replaced lamp and still no picture
Good Day;
Bad news this TV has multi problems, check these:
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). Good Luck, big IRISH.
Thank You! Was the solution helpful? if(typeof LIB_LOADED == 'undefined'){document.write(''); }
Aug 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
Nov 08, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Sony KV-32V65 TV Logo
43 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
