Question about Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM W/1HP PUMP
Why is the pressure in my filter shooting on and off
  • 990 Answers
Maybe low water or check your skimmer weir door and be sure it is free and not sticking in the up position.
Posted on Jul 14, 2010
What is next on trouble shooting fuel injectors?
what engine?
Do you have power to the injectors? if not check the ECM1 fuse. If blown check the wiring harness around the throttle body for pinched wires to the injectors. Really common on the early throttle body engines.
Aug 19, 2015 | 1989 Chevrolet C1500
Where is the fuel sensor on a 1997 jeep grand cherokee
Have you checked the fuel filter? I would pull the fuel line apart before the filter to see if the pump is putting gas into the line. With key on, the pump should run for 2 seconds to pressurize the lines and fuel rail. And when the engine is cranking over, the pump should be running constant and putting gas into the line. If gas shoots out, possibly the filter is clogged or the fuel pressure regulator on the fuel rail is defective. If no gas comes out, possibly the pump filter sock is clogged or the pump is defective.
Very unusual for the pump to run and have NO fuel pressure.
Aug 07, 2014 | 1997 Jeep Grand Cherokee
Why still no fuel pressure
Are you checking fuel pressure at the engine fuel rail with a pressure gauge hooked up, and key on? And you still hear the pump turn on for 2 seconds with key in on position?
There should be pressure in the fuel rail then. If not, is it possible you put the new filter in backwards? I would take off the line going into the filter from the gas tank, and leave off for a test: you're right, the pump turns on for 2 seconds with key on to put pressure in the line and the fuel rail. But then when the engine is cranking, the pump is turned back on. To check if the pump is picking up fuel, have someone crank the engine over while you watch at the filter: gas should shoot out in a good stream. If it doesn't, check for a kinked line from filter to the tank. If the line is good, you will have to take the tank back off and see why the pump is not picking up fuel and sending it out.
Let me know what you find. If the pump shoots out gas at the filter area, but still no fuel pressure at the engine, check the line from the filter to the engine-may be kinked, blocked, or clogged.
Jun 08, 2014 | 2001 Ford Windstar
Sand Filter Shoots out water like Crazy! is it Pressure? Please help
Is this a problem? What is "Like Crazy" ???
Normally this is a good thing.
Exactly what do you mean?
Water shooting out, is Pressure.
Aug 24, 2013 | INTEX Sand Filter Pump
No pressure for the filter outlet.
it sounds like the filter is clogged somewhere
May 09, 2012 | Intex 2100 Gph 95 Hp Sand Filter Pump With...
Oil is shooting out truck
WELL IF ITS ENGINE OIL SHOOTING OUT CHECK AROUND OIL PRESSURE SENDING UNIT AND OIL FILTER SEAL LEAKING OR OIL FILTER HAS A HOLE IN IT. IF YOU TALKING ABOUT TRANSMISSION CHECK TRANSMISSION COOLER LINES GOING FROM TRANSMISSION TO RADIATOR.
Sep 18, 2011 | 1998 GMC Yukon
Hayward 1.5 hp sand filter
Hi i have a Hayward S-180 sand filter and when i clean the pool green algie shoots back into the pool.
Jul 26, 2010 | Hayward SAND FILTER, PRO SERIES
I have a 7 hp B&G craftsman Pressure washer , if I place an air filter on it ,it wound't start or run , if I remove the air filter it would run like a champ, but after 10 mints , oil would shoot out...
First,
It sounds like the air filter is full of dirt preventing air from flowing through, starving the engine of air.
As for the oil shooting through, are you certain the oil is coming from teh carb?. Makes no sense the engine would run if it also shoots oil out the carb. There is nothing in the engine that would cause this, assuming it's a gasoline engine. And I am not sure a diesel would do this either.
Dec 17, 2009 | Briggs & Stratton Pressure Washer...
Blow back out value cover and oil stick
your internal pressures are too high!!!!!!!
change the pcv valve and get the oil filter checked. Sometimes the oil filter will block and the oil pump will over pressurize the engine. See a mechanic Soon!!!
Jun 23, 2009 | 1996 Nissan Maxima
Locating the fuel filter
You didn't state the year or engine size,,,, On the firewall,( passenger side, back of engine compartment, it's round) on fuel injected models, relieve pressure of fuel line before beginning- gas cap off,also must release pressure on fuel injected models- some have pressure release on top of filter, others on fuel rail,this will be a bolt on top of a bolt. Hold the bottom bolt (w/ open end wrench, loosen top bolt w/ 6mm wrench. Cover with rag, so you don't have gas shooting up in your face. Carb models: have 2 filters, one inline in engine compartment, 2nd under car attached to fuel tank. Open gas cap to relieve pressure before starting removal on carb models. countrycurt0
Jul 30, 2008 | 1992 Honda Accord
Open Questions:
See all Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM W/1HP Questions
Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM W/1HP PUMP Logo
127 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
