Question about Compaq Presario 5000 PC Desktop
'cpu at 100%'
'cpu at 100% after stand-by'
  • 6,826 Answers
OK, try to revert to a prior restore point on the Presario 5000 PC Desktop. You may be surprised at how much faster it runs, also, if you recover to the original factory settings, and allow it to automatically update through the Internet.
Good luck, if you can do it, seeing that the system is probably locked up presently.
Posted on Jul 13, 2010
Compaq Presario SR5402FH pc powers down, cpu fan failing
- Clean the CPU Fan with blower.
If while performing any step cpu goes to 100% then it seems problem can be due to hidden background running services, so i would suggest you to disable them with the help of Reginout, download it.
Nov 25, 2013 | HEWLETT-PACKARD Compaq Presario SR5402FH...
100% cpu usage
In Task Manager, go to the Processes tab and sort by the CPU column. See what is hogging up all your CPU. It may be a virus, if so, I recommend downloading Malware Bytes and doing a full scan. Warning, it could take several hours to scan depending on the size of your machine. Good luck!
Nov 23, 2013 | Patrick M. Kolla Spybot - Search &...
What can I do about cpu reading 100%
Check what programs are taking up the most CPU resources, i.e. invoke the Windows Task Manager (use Ctrl + Shift + Escape or Ctrl + Alt + Delete, or simply right click on the Task Bar and select the option).
Look on the Processes page tab and click on the CPU column heading to order the usage by the maximum to minimum, then watch to see what is taking the most resources.
Jan 16, 2012 | Computers & Internet
How to configure a MP080 motherboard using socket type 7 for a Intel 100 MHz 296-pin SPGA processor(hopeing for a video clip; some sort of visual aid on how to
Look at the CPU-socket on the motherboard.
There will be "holes" in only _some_ of the corners of the grid of holes.
It is a 'ZIF' ("zero insert force") socket, meaning that if you have to "push" the CPU to get it into the socket, you are doing SOMETHING WRONG.
Look for a lever on one side of the socket.
Gently pull the lever SLIGHTLY "away" from the socket, to "unlock" it, and then rotate the lever 90 degrees.
Look at your CPU -- there will be matching pins (and omitted pins) at each corner of the grid of pins.
Match the pins with the holes, and put the CPU into the socket. Use that "lever" to lower the CPU into the socket.
Most motherboards will "auto-detect" that you have a 100 Mhz FSB ("front side bus") on your CPU, and the CPU itself will clock itself, e.g., a CPU rated at 2000 Mhz will "multiply" the FSB bus by 20 (2000 == 100 * 20) to drive the CPU at its rated speed.
Jun 01, 2010 | Office Equipment & Supplies
Missing motherboard interupt. CPU running 100%
Most likely you've got a virus or spyware hogging up CPU cycles. Get a good anti-virus/anti-spyware program like Norton/Symantec or Kaspersky and do a full system scan to eliminate viruses and spyware.
Jan 01, 2010 | Gigabyte GA-7VA Motherboard
100% cpu when connected to the internet
Try to find application that load the CPU at 100% by seeing TASKMANAGER.
To start TASKMANAGER press CTRL+ALT+DEL on the keyboard, select PROCESSES TAB, click on CPU to order by CPU load and find process that come near to 100%.
Oct 18, 2009 | Intel D915GAG Socket 775 Motherboard -...
Casio e-100 questions......help!
Are you trying to install programs that run on your desktop to the pda? If that's the case, you cannot do it. The softwares for pda need to be written and compiled for your particular cpu and os.
Sep 06, 2005 | Casio Cassiopeia E-100 Pocket PC
Compaq Presario 5000 PC Desktop Logo
77 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
