Question about Canon PowerShot SD870 IS Digital Camera
I have had my canon 870is for about 1 1/2 yrs & love it-I have never had any problems until today-the battery flashed red(dead) & I removed it & charged it...Well, now since I put it back in & try to use it the flash will not work?The little orange sensor on the front lights up & makes a noise like it is trying to work...but nothing?
    Novelist:
  • 178 Answers
Depending on how long your camera has been put away for, and in what conditions it could be either with the camera or the battery itself.
If the battery is older it won't hold the charge, so even charging it and immediately placing in the camera it won't have enough energy to power it on and stay on.
You can try to purchase a new battery for the camera, make sure it is the manufacturer indicated battery. Often people try other batteries and they don't work. it does make a difference.
This company is very reliable http://www.teleplancamerarepair.com/Canon_Powershot_SD870_IS
and they also clean the camera as part of their repair services.
Make sure you tell them what is going for it could be something with the built in flash, or a camera sensor.
Try the battery first.
Posted on Jul 13, 2010
Testimonial: "Thanks for your input- I appreciate it! I will check into your suggestions."
Hi . . I have canon 870is and i have problems with my lens .. is not come out when I started the camera . . and its wink a green light next to the play bottom . . and after it shut down alone .. what I have to do ?
Posted on Aug 17, 2010
4 Suggested Answers
SOURCE: My canon powershot a640's flash isnt flashing.
I can't believe I just managed to fix exactly this problem on my camera.  Warning - the process hurt somewhat, but it did work.
I dismantled the case very carefully:  After taking the shiny grey cover on the screen end off (3 screws, noting carefully where each screw was), I took the top cover off.
That was a case of unscrewing three screws at the bottom of the battery compartment (I left them in place, as it looked tricky to locate them again, subsequently working with the camera upside down), then gently prising the top off - there is an internal clip just next to the visual viewfinder, which you have to wiggle a bit - just use a fingernail to prise it open.  The top lifts off - dangling on with its cable.
Here is the unpleasant bit.  Quite accidentally, I shorted the flash capacitor, by touching its circuit board - and got the most surprising electric shock.
I looked around to see if there was anything else I would be able to do, felt there wasn't, so I put it all back together, in the hopes that it might have fixed my problem.
Hey presto, I now have a working camera with working flash!
Posted on Dec 20, 2008
mcomijohns
  • 477 Answers
SOURCE: camera was working fine...all of a sudden,it would not turn on...thought maybe battery was dead,tried to recharge it,light would not go on,tried another charged battery,still would not work
This error is either a flash circuit or a lens error. One of the two need replacement.
Posted on May 25, 2009
chelseawells
  • 11 Answers
SOURCE: will not turn on
This is likely the cause of an internal screw that has come loose, it's very common on the G9. A great place to get help with this G9 problem is: camerasandparts.com since they just specialize in these powershots. They not only have the fix available but they have the correction so this never comes back, that comes with their no power service for the G9's automatically. I hope that helps, that's the place if you need help with a powershot, best of luck
Posted on Jun 24, 2010
Is there a fill in flash setting for the canon 870is?
Press the button with the lightning bolt icon until the lightning bolt appears by itself on the screen. It will now flash on every shot.
Feb 19, 2010 | Canon PowerShot SD870 IS Digital Camera
A640 freeezes while taking pictures
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Sep 27, 2009 | Canon PowerShot A640 Digital Camera
Canon Powershot 870IS accidentally submerged in water.
when the camera falls in the water, only the power supply would have got bad, just take it to the manufacture, he will replace the power unit, it will work as good as the new one,, thank you,, plz rate me
Jun 30, 2009 | Canon PowerShot SD870 IS Digital Camera
Red icon flashing on the display screen
It's the warning to replace teh back up battery housed behind the main battery.
May 28, 2009 | Canon MV830 Mini DV Digital Camcorder
A red icon flashing on the screen.
It's the warning to replace the back up batter which is housed behind the main battery.
Red crossed horizontal icon flashes on screen
It's the warning to replace the backup battery which is housed behind the main battery.
Battery Dont Charge
I had the same problem. I had a 1 year warranty, so I called 1800-435-7732 and they sent me a new battery within 5 days. I just received it today and it works perfectly. Hope this helps you! =]
Dec 26, 2008 | Casio Exilim EX-Z77 Digital Camera
Flash use "kills battery dead"
The most likely culprit is a several year old battery that is not accepting or holding a sufficient charge. Turning the camera on, and taking a non-flash photo may not tax the battery too much. However, when the flash is called for, the power demand may exceed the battery's ability to deliver enough juice. A new(er) battery is probably your best bet to resolve the problem.
Mar 23, 2008 | Canon PowerShot S50 Digital Camera
Canon A310 Won't Power Up.
Try checking this... on the battery door (the outside door) along the top edge (over the CF card pointer embossed in the back of the door) you should see a little plastic piece that pokes out... tis is supposed to push a small switch located in a slot over the battery compartment. It's the sensor that tells if the battery door is open or closed.. if the plastic part breaks off or gets chipped it wont push the button and the camera will not turn on when the shutter door is opened.
Jun 09, 2007 | Canon PowerShot A310 Digital Camera
Canon PowerShot SD870 IS Digital Camera Logo
324 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
