Question about Canon Office Equipment & Supplies
I have A Canon Pixma MP-530 Printer,Fax,Copy Machine that's a couple of years old. It recently started making some weird loud grinding noises although it's still functioning okay. Would anyone know what that is and if it can be fixed or should I just wait 'til the machine implodes and get a new one.
  • Canon Master
  • 6,826 Answers
On the Canon Pixma MP-530 printer, there are rubber rollers controlled by sprockets and belts.
If you hear loud grinding noises coming from it, consider yourself lucky that it hasn't come to a 'grinding' halt.
I think you should have it fixed by an authorized service center for Canon, if you have the extended warranty. Otherwise, it is probably not cost effective to have it repaired.
I would do the latter, wait for the machine to implode and get a new one, unless it has sentimental value to you.
Cheers.
Posted on Jul 13, 2010
  • 666 Answers
Best bet would be to wait till it blows up or even purchase another now so when it does go out you dont have to wait long but maintenance on a machine of that age is always gonna be more costly than finding a new one
hope this helps
Robb
Canon 4570dn squeals loudly when drawing from MP Tray
Hi
It sound like friction noises. it could be because of the rollers and lubrictaion on gears that got hard creating the noise and also produce strain on the feed motor . I would sugest a good service on all mechanical parts.
Dec 05, 2013 | Canon Office Equipment & Supplies
Canon mp 530 can access the printer but cannot access the scanner from my laptop I recently had to install Vista home premium on my laptop and some files have been moved. I found the scanner icon in the...
have the printer reinstalled in your Vista as the printer and the scanner needs vista drivers to make them work in the same machine.
the drivers can be found in the linke below:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13371
Sep 21, 2009 | Canon PIXMA MP530 All-In-One InkJet...
My canon pixma mp530 makes a loud noise most times when it powers up and when i print a document. It works OK otherwise.
My MP-530 would try to boot up making a noise like something slipping or grinding, ending with ERROR Code 5100.
Solution: Open the Lid. The drive belt was loose and not able to drive the carriage. There is a gear on the right side of the carriage and a pulley on the left side of the carriage. The spring which holds the pulley tight is missing or broken. I was not able to see the tension spring. To put tension on the pulley, to tighten the drive belt, I cut a Popsicle stick into a wedge and inserted it into the middle slot right of the pulley.
Close the lid and power back on. Runs like new. Hope this helps.
Jul 31, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Cannon pixma mp 610 printer paper feed making loud noise no feed
Replace the pickup rollers and check the Gears if they become bad.
Best Regards
Mar 11, 2009 | Canon Office Equipment & Supplies
Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
Jan 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp 530 fax
All in one fax MP530
Fax will not work.Memory full.How to empty memory?
Thanks
Nov 26, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Scanner connection to the PC
i solved mine by replacing the usb cable with one that is 2.00 high speed and inti noise shelded benton-r
Nov 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Can't use the fax on my Canon MP 530
There are 2 ports on the rear, 1 for the incomming phone line, and one to plug in a telephone handset (passthrough) if the telephone line is plugged into the wrong port, the fax machine is unable to dial properly, So try plugging into the other port on the back, it's just next to the other port hope this helps
Aug 27, 2007 | Canon PIXMA MP530 All-In-One InkJet...
183 people viewed this question
old marine
old marine
