Question about Caravell Bulova Caravelle watch
I have a Bulova A4 strap type Gold case with a stainless steel square back. I want to replace the battery ?????
Looking for band for invicta sea spider 1261..i want to replace it with a stainless steel band..
Sea Spider 1261 INVICTA Sea Spider Men 50mm Stainless Steel Gold Black dial 3600K Mechanical watch located attached link offers multiple compatible straps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jamie_580d75bd3bb6d659
Nov 11, 2017 | Invicta Watches
Need to replace or repair a Bulova watch band C877668. One of the links broke. Stainless steel backing
I took mine to a watch repair shop but make sure your watch is worth repairing as it's not cheap.
Dec 31, 2015 | Bulova Watches
98b104 crown broken
best to go to a bulova dealer to get the original fitted as its most likely the stem is sheered of inside the old crown if however it has just unscrewed from the stem any good watchmaker should be able to refit it and reseal it
May 08, 2014 | Bulova 98B104 Mens Watch Gold Tone...
Any idea what a Bulova watch, 14K white gold, number on back case 962158. Any idea what it is worth?
I'd need more info. First, is it a "real" Accutron, made from '60 to '77, or is it one of the things Bulova kept calling Accutrons after they stopped making the tuning fork movement watches? The quartz so-called Accutrons are just a nice old watch, not worth anything special. The self-wind "Accutrons", which Bulova is making now, are just a nice, mid-range aurtomatic watch. On the back of Bulova watches is a date code, usually right under the serial number (SNs themselves really mean nothing where Accutrons are concerned). The code is a letter and a number. If it begins with the letter M, or if it begins with the letter N and is followed with a 0, 1. 2. 3. 4. 5. or 6, it is a "real" Accutron, and is collectible. Some with N7 (1977) are also, but it depends on the actual watch. Bulova did make some quartz so-called Accutrons in '77. If it's a '60 thru '76, and SOME '77s, it has value beyond the scrap gold price. SOME Accutrons are even worth thousands of dollars. White gold Accutrons, compared o yellow gold or stainless, are rarer. Next, WHICH Accutron is it? is it a 214, a 218, a 219, a 220, a 224, or a 230? If it's a man's watch, it is very unlikely to be a 220 or 230 series, If it does not have a winding stem on the side, it is a 214. 214s are the most valuable. If it has a setting stem at 3 o'clock or 4 o'clock, it is either a 218 or 219 (I'd have to open the back and look at the movement to say which ine). If it says "Accuquartz" on the face, it's a 224 (NOT a quartz - the 224 Accuquartz is a hybrid of tuning fork and quartz crystal). Once we know the movement series, we need the case type. Certain cases are much more valuable than others. Then there are the Spaceview, the Astronaut, and the Deep Sea, 3 specific models they made, which are more valuable than most (but not all) of the other cases. The best I can say right now is that, being white gold, there's a good chance it's one of the more desireable specific models. If it's a 214, ESPECIALLY if it's a 1960 (M0), it's worth quite a bit more than just the gold content. To be more specific, I'd have to see a picture of the watch, which I don't think can be posted here. Try looking up "Accutron" on Ebay and see if you can find one that, if yours has a stem, has it in the same place as yours, with the exact same case - same shape, and exact same lugs (the things on either end where the band or strap is attached). Read the description. The description will probably say the movement (214, 218, etc - in fact, the movement may even be in the listing title) and if it is niot just a plain round case, probbly will say the case type (Alpha, Asymmetric, Butterfly, etc.). If it's an Astronaut, a Spaceview, or a Deep Sea, it will certainly say that. Also, look at the Accutron section of the Bulova entry in Wikipedia. (Yeah, I wrote it, but it has info that just might help you pin down exactly what you have) When you find out more about which Accutron it is, post another question under Axcutron watches here. I'll check every couple of days for the next week or so, and if I see your post, I'll narrow down the value some more.
Sep 17, 2013 | Accutron Swiss Watch by Bulova 26B44
I have a Bulova Watch that was given to a Clark Candy employee with a Serial Number of 523791. Looking for what year it was made and is it worth anything
The value of your watch depends greatly on the model / style, age, and case composition. It goes without saying, but watches (of any mechanical quality) that have real gold cases right now are worth quite a bit more than watches with gold plated, gold filled, gold-tone, or stainless steel cases. Presentation watches like those given to employees upon retirement were often gold or gold-filled--but there's a world of difference in value between those two types of watches.
In terms of age, it's much easier to date vintage Bulova watches by their "year code" than by their serial number. If you look carefully, usually above or below the serial number, you'll see a little alphanumeric code, like L5, N3, or P6. These can be translated as follows:
Lx = 195x Mx = 196x Nx = 197x Px = 198x Tx = 199x
Pre-1947 Bulova watches used little symbols to show the year of manufacture. A picture of those codes can be found here, as well as elsewhere on the Internet:
http://www.manleyhorlogerie.com/Watch_History/bulova.htm#Bulova%20Date%20Codes
Jul 24, 2011 | Bulova Watches
I have a 7 year old Raymond Weil Women's Parsifal watch, stainless steel, bracelet, rectangular face. The outer face in stainless steel, that has four roman numerals on it, has somehow fallen off, or...
If you are talking about the bezel, which is the bit on the outside of the watch, you should contact the Raymond Weil repair centre SWICO. They repaired my Othello when half the bezel fell off. They had it back to me in no time! Their details are on the Raymond Weil website:
http://www.raymondweiluk.co.uk/t-faq.aspx
Good luck
May 11, 2010 | Raymond Weil Watches Tradition 18K Gold...
Appraise Bulova N2 10K R.G.P. Bezel Stainless steel back
I have seen this watch sale in mint condition for as much as $40 but this is an inexpensive piece.
Sep 14, 2009 | Watches
Can't open Geneve OGW154 gold wrist watch to replace the battery
You are right, this type of watch can be opened by lifting crystal and extruding the stem. As for lifting the crystal you need a specialized tool, there is no other way then to go and find your nearest watchmakers shop. If you will try to lift the crystal using knife or any other unspecified tool, you will damage the crystal. Even if you will be lucky enough to get it out without any damage, you will not be able to fit it back, because the watch crystal setting tool reduces the crystal diameter for easy fitting.
Best solution for you is to see the watchmaker and ask for help.
Do not forget to rate, please.
Feb 08, 2009 | Bulova Harley Davidson Pendant . Locket...
Caravell Bulova Caravelle  watch Logo
274 people viewed this question
Top Caravell Watches Experts
Vernon Taylor
Are you a Caravell Watch Expert? Answer questions, earn points and help others
