Question about RCA F27664 27" TV
I GET AN ERROR ON MY TV THAT SAYS " THIS CHANNEL HAS NOT BEEN APPROVED FOR VIEWING. CHANGE CHANNEL OR PRESS OK TO ENTER PASSWORD AND DEACTIVATE THE PARENTAL CONTROL" ITS SAME ON ALL THE CHANNEL. WORST THING IS THAT I NEVER SET ANY CODE.
  • 4,102 Answers
Hi, have you tried pressing 0000 or 1234 or 00000 or 12345 these are usually the preset codes if none of these works then the parental code has been set by your service provider so the only other way of getting this is to contact the people who provide your tv such as cable company or sky company, if you have a cable box then the code is sometimes the last 4 digits of the viewing card so look on the back of this if you have one, failing that you could have a problem with your cable connection so you will need to contact them to find out if the service is down in your area.
let me know what you find out,
if the code is not with your service provider and the code is something on the tellys settings then this would point towards a fault with the telly.
let me know how you receive your channels and let me know what you find out ok
Posted on Jul 13, 2010
  • 2 more comments
  • rohanhpatel2 Jul 13, 2010
    got it to work using code 9999
  • paul proctor Jul 13, 2010
    hi, glad you got it sorted they usually use something simple for the preset code.
    it got fixed with another problem. Now i dont have volume . is there a way to test speakers??
  • paul proctor Jul 14, 2010
    hi if you have your cable or sky plugged into the back of your telly then unplug it from the telly switch it all off at the mains then refit the cables making sure you push them in far enough, most of the time static can cause loss of sound so undoing the leads will earth the static out and should get your sound back.
    also make sure the mute button has not been pressed on the remote
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have an Akai PT5492S television that I don't know the v-chip password to and need to reset the v-chip password.
SETTING V-CHIP
This TV is fitted with a V-CHIP controller which provides you with channel viewing access controls
and restrictions. This function is to prevent your children from watching violence or sexual scenes
that you may choose to exclude.
Press the MENU button and press the SET + or – button to select the V-CHIP SET option,
then press the ENTER button.
Enter your password (4 digits) using the Direct channel selection buttons (0-9).
In the event of entering incorrect password press the RESET button. Then press the
ENTER button.
Enter the same password for confirmation, then press the ENTER button.
Press the SET + or – button to select the V-CHIP option.
Press the ENTER button to select the ON.
Press the SET + or – button to select the TV RATING or MOVIE RATING option. Press
the ENTER button.
Press the SET + or – button to select the desired rating for the applicable video or TV
channel. Press the ENTER button.
And to change or put in a new password:
NOTES:
• If you want to change password, follow steps 1 and 2 and select "CHANGE PASSWORD"
option then enter your new password.
• The V-Chip function is activated only on programs and tapes that have the rating signal.
• Once you block a program using the V-Chip function, the blocked program cannot be watched
based on the content of the show. When the program starts, the "INPUT PASSWORD" will
appear on the screen. When you want to release the V-Chip temporarily, enter the password.
If you change the channel or turn off the TV while the V-Chip function was temporarily released,
the original setting will be resumed. If you return to the channel you were watching you must
re-enter your password to temporarily release your V-Chip function again.
• When you watch the TV from the cable box or the VCR with the RF Modulator, then you release
the V-Chip temporarily, the V-Chip setting will not be resumed until you turn off the TV. The
TV channel is not used in this case.
• When changing the channel with the cable box or the VCR, approximately 10 seconds will
pass until the program appears.
Feb 13, 2010 | Akai PT5492S 54" Rear Projection...
The v chip locks up how do we remove this if dont have code for good on hd 1080 is there a code change to remove the original
SETTING V-CHIP
ENTER button.
the ENTER button.
NOTES:
Hope this helps.
Jan 21, 2010 | Mitsubishi WS-55807 TV
Directv tech support told me to turn off the V-chip on my Sony Bravia TV to program the tv to my Directv remote. How?
SETTING V-CHIP
ENTER button.
the ENTER button.
NOTES:
Jan 21, 2010 | Durabrand DU1301 TV
How to reset password for Parental control or timer? TV shuts off after viewing for about 40 min to an hour.
RCA R52WH73 Television
Press MENU and select "Parental Controls". Simultaneously press the CH+ and VOL+ on the front panel for 8 seconds.
Select new password if desired.
Good luck,
Techjoel
May 11, 2009 | RCA R52WH73 Projection Television
Parental lock
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
V-chip or parental control
SETTING V-CHIP
ENTER button.
the ENTER button.
NOTES:
End of manual text.
try this thx nick
Feb 07, 2008 | Curtis-Mathis CM32010 TV
Televison problem
Have you had any storms come around recently? This sounds like the EEPROM IC is corrupt and probably needs to be changed. If you know how to solder maybe you can change it your self. If your not good at soldering then you can have a pro assist you with this repair Good Luck
Jul 24, 2006 | RCA 27F530T 27" TV
C13A05LG code
To Remove Channel From PC: 1. Deactivate PC. 2. Enter the channel number you wish to remove from PC. 3. Press the PC button, followed by the CE button. The channel is now removed from PC an may be viewed by anyone. Note: If the 4-digit number has been forgotten, the decoder is designed to automatically unlock after 24 hours, provided that it remains plugged in
Jan 02, 2006 | Zenith C13A05LG 13" TV
RCA F27664 27" TV Logo
26 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
