Question about Husqvarna 450 e-series 18" Chain Saw
Hi, I go t a new Husqvarna 450. It cut fine for 10 mins and then stopped cutting well. Engine runs fine but it barely cuts at all. The cut is black as if burned and there's sparks from the chain on the bar. The edge of the bar is blackened even though the oil is working ok. please help.
  • Garry Clelland Jul 14, 2010
    hi, take your saw to a local dealer and have the chain checked and sharpened , try and get them to show you the proper way to tension and sharpen your chain ( you will need a file and guide properly setup for the type of chain your using ) you may also need to file off the high spots on your chain bar or replace it if the bar is badly scorched or bent . remember a chainsaw requires daily maintenance ( 2 stoke mix, clean air filter, chain oil filled up , chain sharp and properly tensioned ) hope this helps. p.s try not to cut into soil :)
  • Joe Bannon Jul 16, 2010
    Thanks for your help. The problem has been solved. The chain must have hit a pocket of dirt which blunted it and pulled dirt into the oil groove on the bar.
    Brigadier General:
  • 4,088 Answers
Suspect that the chain hit a rock or pocket of dirt which will dull the chain in a heartbeat plus pull debris into the chain groove area. Remove the bar and chain and clean everything thoroughly including the chain and bar groove. Inspect the chain teeth carefully looking for burned teeth and other physical damage. If badly damaged, suggest replacing the chain. It's not likely that the bar sliding surfaces have been severely damaged. When you have everything back together and the chain adjusted, start the saw and run the bar tip near some cardboard--it should throw off a thin line of oil in a few moments. There should be an oil volume adjustment screw on the back or just under the same area near the chain return. Turn the screw CCW to increase flow. Hope this helps!
Posted on Jul 14, 2010
Testimonial: "Thanks a million. That has solved the problem."
Starts fine, run fine,for about 2 to 5 min.,then cuts off,sounds like it's not getting the gas.
I have a Husqvarna 125B same problem. Turned out to be a bad gas cap. Doesn't vent properly and starves the engine. I took the gas cap off of my Huqvarna weed eater and put on blower and blower worked fine,
Nov 11, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Husqvarna 450 chainsaw used about 1 hour out of the box cutting fine then the blade stops. hard to get clutch cover off and now cant get it back on
Sounds like the brake has come on, grab the hand guard and pull it firmly right back to the top handle, this should load the brake.
Sep 18, 2011 | Husqvarna Garden
I have a 450, and I would like to increase my bar oil output. Where is the adjustment screw? Please!
There is no adjuster for the Husqvarna 450. Husqvarna recommend that if there's not enough oil reaching the bar that you slow down the engine by adjusting the carburettor screw. I have the same saw and also wanted to adjust the oil flow. I didn't change the carburettor and it's still cutting away without doing any damage. It's meant to use less than a tank full of oil to the tank full of fuel when you're cutting near constantly. With stops in between it will use more fuel and less oil.
Nov 08, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Hi there, cutting out in traffic
camshaft sensor need repalcing, simple fix is, have a bottle water with u, when engine cut out pour slowly some water on top of engine where the sensor is located, it cool down fast then u can start again and continue drive until it too hot again,
sensor is located on top of engine close to firewall in the middle.
Apr 19, 2010 | 1999 Suzuki Grand Vitara
Saw starts but engine cuts out after less then one
i think you really need fresh fuel, clean out tank as much as poss with new oil also. will probably take a while to pump fuel through
Mar 06, 2010 | Husqvarna 450 e-series 18" Chain Saw
The chain slows down or stops when cutting. The engine runs fine and doesn not slow down. I checked the oil, cleared the oil vents to the chain, the brake is fine and is not causing the problem. The...
THE SAW IS RUNNING FINE . WHEN THE CHAIN STOPS AND THE ENGINE IS STILL RUNNING AT HI THROTTLE THE CLUTCH MAY BE WORN AND SLIPPING. PULL THE CHAIN AND BAR AND SEE IF THE CLUTCH HOUSING IS BLUEISH IN COLOR IF SO I WOULD REPLACE THE CLUTCH
Sep 17, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My 1987 Lincoln Town Car runs fine for about 30 min and shuts off
replace fuel filter and (clean or replace) air filter. then pressure test fuel system.
May 14, 2009 | 1987 Lincoln Town Car
Husqvarna 450 e-series 18" Chain Saw Logo
495 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
