Question about Sewing Machines
Thread an overlock machine
How to thread an overlock machine
  • 135 Answers
Viking makes a very good picture diagram. Since you have to thread it differently for every stitch the diagram would be your best bet and you would always have it to look at. Visit your local Viking dealer and they would be happy to show you and get you the diagram.
Posted on Aug 19, 2010
Help plse, after threading it dont make the overlocking stitches. New machine, help with right way to thread machine and the smaller detail of threading.
Your machine is either not threaded correctly, or the individual threads have not been threaded in order. Be sure to ALWAYS RAISE the presser foot when threading the machine. You must follow the instructions exactly or the machine will most likely never work properly. Can you at least get a training class on your machine? A class is indispensable, especially when it comes to using a serger.
Even if it is not the same model, these instructions may be helpful.
Tutorial for threading overlocker
Make It Handmade Threading Your Serger or Overlocker
Need manual for an empisal 754D overlocker can get the tension right and...
Dec 14, 2016 | Sewing Machines
How to thread a Empisal overlocker.. model 760C
Perhaps the manual would help:
Empisal Overlocker 760C Empisal Sewing Machines
On most machines, it is important to ALWAYS raise the presser foot when threading the machine (although the instruction manual says to raise the presser foot only to pull the thread tail under it). Be sure to give the thread an extra little tug when going through the tension disk to seat it properly. Be sure to thread in the order as specified (Upper looper, Lower looper, Right needle, Left Needle). If the machine messes up, it is usually a best policy to remove all the thread and rethread from the beginning. Threading out of order will almost guarantee failure!!!
Jul 20, 2016 | Sewing Machines
Problem with an overlocker that does not overlock
You may need to rethread all the threads because most sergers need to be threaded in the right sequence. I looks like this one has to be threaded starting at the right and progressing left.
Jan 20, 2014 | Janome Sewing Machines
My pegasus industrial 5 spool overlocker type L52-18S1 spec 2x4 dose not overlock in the threads
the machine may need to be taken in to be checked to see if it's
out of time
Jun 07, 2012 | Sewing Machines
I'm not sure how to thread my machine, I lost my manual elna lock pro 5Dc
I would suggest that you buy a new manual for this as your overlocker has 5 threads that need to be threaded up correctly to form a stitch and there are several different stitches that can be made with this model such as a rolled hem, chain stitch, three thread overlock, four thread overlock and safety stitch with three thread overlock, lots to learn.
You can buy a manual here for $USD14.99: http://www.sewingpartsonline.com/instruction-manual-elna-pro5dc.aspx
or this website has a copy for $USD10.
http://www.sewusa.com/Sewing_Machine_Manuals/Elna_Manuals/Pro_4DC_DE_Instruction_Manual.htm
Always well worth buying the manual and saving a lot of frustration trying to guess how things work and it adds value if you are going to sell the item.
You can get some general overlocker threading tips from http://sewing.about.com/od/sergersoverlock/ss/serger.htm which may help you too.
Aug 31, 2011 | Sewing Machines
Sould i use overlock thead on my brother embroidery/sewing maching
It is, of course, possible to use overlock thread in a typical machine. Generally speaking, you only want to use overlock thread to overlock ("serge"). The reason for this if that while typical all-purpose or sewing machine thread has 3 strings wound together, overlock thread has only 2. When you are using 3, 4, or even 8 threads at a time with a serger, each strand doesn't necessarily have to be as strong as when you are sewing on a machine with only 2 threads. So, you physically could use the thread, yes, but it will not be near as strong, and you will probably have issues with breakage while sewing as well. The cost savings you think you may be saving by using overlock thread (which is, after all, considerably cheaper per yard), well soon be overrun with extra time sewing due to broken threads and overall less quality in your garment as it will be made weaker.
Jun 19, 2011 | Brother Lay-In Thread Serger Mechanical...
How do i thread a janome overlocker
there's a good you tube video and threading an overlocker
Jun 01, 2010 | Janome MyLock 634D Mechanical Sewing...
Thread wont overlock
When the thread breaks too often, try these, that goes for all sewing machines
1. Replace the needles,
2. Loosen slightly the tension of the needle threads.
3. The top threads are to thin,
4.The sewing (rotary) hook or looper, has burs,
5. Wrong threading
May 21, 2008 | Husqvarna Viking 1
Sewing Machines Logo
312 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
