Question about Kenmore 75085 Air Conditioner
Electrical cord was accidentally pulled out of ac unit.
How do I reattach the cord--with its three wires-to the ac unit? I am having difficulty figuring out how to open the control panel cover to reattach wires.
    New Friend:
Green is ground, secure to frame. White goes to compressor, located behind LED/LCD, lower right corner you'll see a number of other colored wires kind of in a circle, each connected to a 'port'. The black goes behind LED/LCD panel also. Top far right, back corner. 2 ports are connected to a black box..a red one and should b your black one.
GOOD LUCK!
Posted on Jul 09, 2014
2 Suggested Answers
  • 1015 Answers
SOURCE: with a Kenmore 8000 BTU ac window unit there is a
Most of the time a green wire is a ground and should be attached to the metal frame using a existing screw or a self tapping sheet metal screw. Thank you.
Posted on Aug 26, 2011
No electric output, how do I diagnose, capacitor, proper winding check etc.
Have you tried flashing your generator? Sometimes the magnets in the generator loose their polarity. Google and YouTube "flashing a generator"
HFLASHING the GEN
Sometimes the magnets lose their polarity. This worked on my brothers $1200 gen. Its worth a try. Good luck!
Check all wires/connections first, Then try this-
(Remove spark plug wire first!)
To flash the field on a small home use generator, get an ext. cord & cut off the female end of it & strip the wires & connect the wires to a 12 volt car or lawn tractor battery, & plug the male end of the cord, into the 120 A.C. side of the generator.
Make SURE that the black wire which is POS/HOT on an A.C. cord, gets connected to the RED/POS. side of the auto battery, & the white wire on A.C. cord gets connected to the BLK./NEG. side of the battery. If the ext. cord wires are not black & white, then the smaller prong of the plug is the POS./HOT
Plug the other end of the ext. cord into the generators 120 volt side (**remove spark plug wire**) & pull the starter cord 4-5 times, then remove the ext. cord, reconnect the spark plug wire, start the unit & plug something of 120 A.C. volts in to see if it works. Then let it run for about a half hour with 2 - 150 watt lights to help re-generate the unit.
Read more:http://www.doityourself.com/forum/outdoor-gasoline-power-equipment-small-engines/188605-recharging-generator-field.html#ixzz29QwjlAOWere's one way-
Dec 17, 2014 | Coleman Cable Coleman 5000w Progen...
Please show me how to reattach the male plugin back to the wire.
JUST REATTACH SAME WIRES BACK TOGETHER USING ELECTRIC TAPE...MAKE SURE CONNECTION IS TIGHT
Apr 04, 2014 | Leviton D6721-15E DuraPort Industrial...
Hi there just fitted brand new bathroom pull cord.... works but have to pull it three times. Any ideas why ? Thanks Lydia
if the wires are correctly installed, and tight. then you may have a bad pull chain switch. good-day ! but first turn off electric, and see if the wires are not loose and the wire nuts are tight behind light.
Feb 16, 2012 | Duravit Home
How do you change the power cord on the Hoover u5475-900 Wind Tunnel 6200? Thanks for your help.
This procedure worked for replacing the cord on my Hoover U6425-900. At a minimum, you will need a number 2 Phillips screwdriver, wire cutter, and two electrical wire nuts and electrical tape. Remove the accessory tools from the storage compartment. Remove two screws, these are recessed. Remove the cover from the bag compartment, remove two screws located at top corners of bag compartment. You may have to open the side filter door but the accessory tool storage compartment should be free at this point and can be removed. You should see the power cord and related wiring. If you have a digital camera you could take a photo at this point in case you need a point of reference. Make note of the power cord strain relief routing and length of wire. Too much wire will make reattaching the storage compartment difficult and the routing prevents the cord from being pulled out.
On my model the wiring colors were purple, orange and white. My replacement cord had black and white wires. The orange wire will not be involved in cord replacement. Using the wire cutters clip the purple wire about three inches back from the existing terminal. If present, clip the two nylon wire ties and discard. The white wire will have a crimped on wire connector. Clip the white wire about three inches back from the existing wire connector. The old power cord can be removed by pulling it out from the rear, it should just slide out of the rubber insulating boot. If not use a set of pliers and crimp the boot from the wiring side and push it outside the vacuum housing. If you have to do this make sure you slip the boot over the replacement cord before you insert the new cord back into the vacuum housing. Remove about a half inch of insulation from the purple and white wires and from your replacement cord unless it was supplied with insulation already removed. Use new wire nuts and connect the white wires. Use the other wire nut and connect the purple wire to the remaining new power cord wire. Use some electrical tape and wrap the nuts to the wires a couple of times so they won't loosen. Make sure you route the power cord around the posts as this is the strain relief and prevents the cord from being pulled out. Reassemble and test.
Feb 03, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Says drum error, see troubleshooting maitainance chapter in user guide. Don't have a users guide. Printer is brother mfc-7340
I have this manual for you. I can be reached at LBrown18062@hotmail.com
http://welcome.solutions.brother.com/bsc/public/as/as_ot/en/doc/manual_index.html?reg=as&type2=-1&prod=mfc7340_us_as&c=as_ot&lang=en&flang=all
Drum Error - The corona wire on the drum unit needs to be cleaned.
Clean the corona wire on the drum unit. (See Cleaning the corona wire on page 122.)
Cleaning the corona wire: If you have print quality problems, clean the
corona wire as follows:
a. Turn off the machine's power switch.
Unplug the telephone line cord first, disconnect all cables, and then unplug
the power cord from the AC power outlet.
b. Open the front cover.
c. Slowly take out the drum unit and toner cartridge assembly.
CAUTION: We recommend that you place the drum unit and toner cartridge assembly on a clean, flat surface with a sheet of disposable paper or cloth underneath it in case you accidentally spill or scatter toner.
Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
To prevent damage to the machine caused by static electricity, DO NOT touch the electrodes shown in the illustration.
d. Clean the corona wire inside the drum unit by gently sliding the green tab from right to left and left to right several times.
CAUTION: Be sure to return the green tab to the home position (a) (1). If you do not, printed pages may have a vertical stripe.
e. Put the drum unit and toner cartridge assembly back in the machine.
f. Close the front cover.
g. Plug the machine's power cord back into the AC power outlet first, and then reconnect all cables and telephone line cord. Turn on the machine's power switch.
Dec 31, 2010 | Brother Office Equipment & Supplies
Need wiring schematics for Haier HWR12XC5 AC
My friend ... you are doing a simple repair ... you don't need a wiring schematic to replace this power cord. When you get the unit open ... you will find the other end of the ripped cord ... black goes to black, white goes to white green goes to green or ground. In fact ... you will trim the end of the cord and reattach it using either crimp connectors or wire nuts.
Thanks for your interest in FixYa.com
May 31, 2010 | Heating & Cooling
Won't turn on
try to replace the ac cord it maybe damaged when it was accidentally pulled out
May 05, 2010 | Sirius Boombox for Select Satellite Radio...
Cannot turn off a pull-chain fixture
It sounds like you have accidentally by-passed the switch. The switch only needs one power leg to the pull-chain switch and the other 3 wires go on the other wire of the switch. The white wires get connected together as you have done.
Please turn off the power before you make a change.
Sep 19, 2009 | Kitchen Appliances - Others
What wires go to which colors while hooking up the dryer plug
Normally a 220V-AC dryer plug will have three (3) wires. Two (2) of these are 120 V-AC each while the third one is the ground wire. The dryer cord (plug set) will have three (3) prongs and three (3) wires with either ring or fork terminals on the other end. The ouside wires are the voltage supply, while the center (middle one) is the ground wire. Your manual should also show this in the installation section for your unit.
Connect them using the installation guide for your dryer, which should show the two outside connections for the power, while the center connection should show as the ground, but BE CAREFUL and check to be sure before plugging in the plug/cord set into the wall 220 V-AC receptacle!!
Typically, newer appliances have a green colored nut/screw indicating the ground connection/conductor.
Jul 13, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Replacing the electrical cord on a Roper Refrigerator
I may be able to assist...If you haven't done so already..UNPLUG The cord. Now, depending on where the wire was severed, will impact the degree of difficulty in reinstalling it.
I suggest that you position the fridge so that you can access the place where the cord actually goes into the fridge.
I assume that the cord passes thru a cable feedthru of some kind in the back so you may want to follow that into the fridge.
If the cord was severed outside the fridge you could simply join the 3 wires together as an inline connection ( making sure to keep the supply line, neutral and ground wires bonded to their corresponding ones ... meaning ground wire to ground wire, neutral to neutral and supply line to supply line... line may sometimes be referred to as the 'hot' feed.
If the cord was svered off internal to the fridge, try these steps..
You will probably need to remove an access panel on the back to see where the power cable is routed within the fridge. Once located, you will need to find where that cord was severed when it was pulled out. There should be 3 wires coming into the fridge from the power cord. I assume it came with a standard three prong plug that is compatible with a wall socket. You will have to identify which wire is which on the cord. It helps if you have a continuity meter or ohm meter for this. First, identify which of the 3 wires is bonded to the round terminal of the plug ( that would be your ground wire) That wire should be secured to the fridge frame with a bare screw of some sort. You may be able to trace the cord inside the fridge back to that point or you may be able to reattach the severed wire together using wire nuts to keep the wires joined together and electrically insulated from surrounding surfaces. Remember that it is critical to maintain the same point to point wire configuration as it came with. As a general rule of thumb, a bare copper wire or green insulated wire is typically the ground wire. Depending on the cord type, black insulated wire is normally the supply or HOT feed, and white is typically the neutral line. You may have different color insulation on your wires ( especially if it is a molded cable assembly ) so make sure you verify which wire comes from which terminal on the plug. ( round terminal on plug is ground, the longer of the two ( if it is a polarized plug would be your neutral and the shorter terminal would be the supply line. If unsure, get professional assistance. Hope this helps...
Aug 06, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Kenmore 75085 Air Conditioner Logo
80 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
