Question about Home Security
I need an installation and user manual for the LTD7726 DVR. I have the manual for LTD7704/7708 but the main menu screens are different from the 7726.
3 Suggested Answers
  • 52086 Answers
SOURCE: Forgot admin password in Hifocus H264 DVR, unable to enter main menu
we do not know passwords here SORRY check with the manufacturer thru their website and technical support
Posted on Jun 15, 2015
Hi. Put here some images of the DVR's front side, the login screen and the WEB interface.
Posted on May 14, 2016
Is there anyway to determine the manufacturer of an unbranded dvr dvs? I forgot the admin password and can't get to main menu
has to have a model and serial number as a sticker on the frame
all being well
google those numbers
its user manual should pop up
from the manual has the brand or maker
Jun 08, 2016 | Home Security
Jun 15, 2015 | Home Security
How can i rest a password on my truvision dvr30
The TVR 30 is shipped with one predefined user for the system administrator and
seven predefined standard users. The default system administrator logon uses admin
as the account name with a default password of 1234. You can modify the admin
password but not the admin user name. The seven predefined standard users are
labeled User1 to User7 with a default password of 4321 and level 4 access. The
administrator can customize the seven standard users and define their privileges.
Use the Users screen (shown in Figure 20 below) to manage users.
Note: When accessing the main menu for the first time, the system lets you pick
either an admin user or a regular user (User 4) by default. If you select User 4, enter
the initial default password of 4321.
Dec 28, 2014 | GE TRUVISION DVR 30 8CH 2TB
How can i change the admin password on a bosch divar
you may go to dvr main menu and find user account or user management
Feb 12, 2014 | Bosch DVR-16K-050A DIVAR MR 16channel., 8...
Screen wont show cameras or record
Are you pressing menu button on the monitor or the DVR?
Your problem may not be the cameras, but between the DVR and the monitor. Found this on page Eng-19 of the user manual which I found on Samsung.com
This monitor was set to password lock when you purchase a new set. Therefore, you must first enter a 4 digit password to activate the On Screen Display... the default password is 4321. Not sure if that helps.
Dec 17, 2013 | Samsung SMT-190DN 8-Channel Security...
Samsung SHR-1041K. Cannot connect to DVR system "Unknown Error"
Samsung 1041k DVR - Camera Web Server Solutions. ' UNKNOWN ERROR' OR 'CANNOT CONNECT TO SERVER'
Holy Smokes! Can't anyone write a simple solution? The manual totally sucks. It tells you everything except the details that will complete the puzzle. The answers here, so far, are written by gearheads who can't write an easy sentence.
1. The user name is case-sensitive. So if you program the DVR with a user name it will only take capital letters by default ... so when entering the user name (USER ID) in the web setup ... It MUST BE CAPITAL LETTERS otherwise you will get an 'unknown error'. There is no mention of this important little fact anywhere....
2. Use Internet Explorer ONLY (becase of old Active X controls), not FireFox, Chrome, or Safari...etc...etc. IE9 doesn't like it either .. just goes white for the most part or flickers ..so IE8 seems to work best.
3: When programming the DVR Box using the MENU button and the 'NETWORK OPTION ...Use Port 6100 in the NET CLIENT PORT. In the WEB SERVER PORT use port 80. The difference is ... port 6100 is used for the basic connection of the network to the DVR device and camera hardware and software ..... and port 80 is for viewing through Internet Explorer. (Port forwarding in the router must direct those ports right back to the IP address of the DVR (whatever you set it to). TCP and UDP together work just fine... not necessarily one or the other . I tried it both ways .. they all work.
4. If you are lucky enough to finally get Internet Explorer to hit the DVR software via the correct IP address and port of the DVR.... then it will prompt you to install the Active X control software embedded in the DVR. You might hae to refresh the screen a couple of times for it to download and install. If indeed it does then you will get a blank box that will wait for you figure out you need to click on a little wrench to configure the DVR connection. Add the DVR (give it a name). Enter the IP address it was configured with .... and set the port to 6100. Remember to capitalize the User Id and put in the password and save .. Completely IGNORE the confusing little matrix boxes that are used for setting up multiple DVRs and cameras. Save the setup, it wil take you back to the blank Samsung box interface and wait till you figure out to hit the connect button in the center. If you did it all correctly then you should connect to the camera views..
4. If you are going to view the cameras from the home network .... then enter the IP address assigned to the DVR PRECEEDED by http:// . Believe it or not it seems to make a difference. If you are viewing from ..say .. your work.. put in the numerical address of your home IP address and if you have the port forwarding set up correctly you will be forwarded directly to the DVR camera software where you can sign in and see the screens.
I have set up many, many IP cameras and various DVRs and software packages professionally.. I must say that this DVR and software is not very intuitive and was very difficult to get past some of the issues. The included instructions were of little help. I hope this helps somebody else.
Gary
Jun 28, 2010 | Samsung 4 Channel Dvr
Can't view my cameras
The DVR will be programmed with an IP Address via the DVR main menu function (network settings) and a valid password. The network viewing software (web viewer) you will need to ensure that the IP address is entered correctly for your DVR along with your valid user password.
Trust the above info is of assistance if you require a manual in order to check your settings try this link http://tv.manualsonline.com/manuals/mfg/samsung/samsung_dvr_product_list.html
May 23, 2010 | Samsung 4 Channel Dvr
I can not get my dvr to conect to my home coumputer
Check your DVR network settings via the main menu function. You will require a IP Address & Passwod. Ensure your ethernet cable is connect from your DVR to your local computer.
You will then need the network viewer software putting on to your PC (normally provided with your DVR). Ensure the IP Address & your user password are entered correctly and then you should be able to connect.
Alternatively, you can utilise a web brouser.
Also have a look at the following link for a manual for the named network camera that you have indicated http://bssc.sel.sony.com/BroadcastandBusiness/docs/manuals/usersguidesncrz25nv1.pdf
Trust all this information is of assistance.
May 22, 2010 | Sony SNCRZ25N Network Camera
Dvr 100 avion
I NEED THE USER MANUAL FOR THE AVION AV-DVR100
Jul 14, 2008 | Avion AV-DVR100 DVD Recorder
Admin password DVR-X4 IP
i lost the dvr password how to watch yastaday data
Mar 11, 2008 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
Home Security Logo
102 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
