Question about Bosch Integra® 500 SHX46L Built-in Dishwasher
Filter getting pluged up;dishes not coming out clean. bought new filter starting to do the same.
  • Bosch Master
  • 2,605 Answers
Hi,welcome to FixYa.
Based on two things you mentioned ( replaced filter because the old one was badly plugged & new one starting to have similar issues ) leads me to wonder, does the unit heat the water.
I ask because if it does not, the detergent will never disolve properly, hence clogging up the sump, filters and everything else with un-disolved detergent.
Does the normal wash generally take 2hrs or more to complete ?
This would also explain the dishes not cleaning very well...or at all.
If you can answer any of these questions I`ve brought up and confirm the model number, I can assist you in solving this issue once and for all.
I`ll watch for your reply.
macmarkus :)
Posted on Jul 13, 2010
My dishes come out dirtier then when they went in. I usually rinse my dishes before I put them in because the dishwasher won't clean them. I tried cleaning the two filters today and this didn't help. I...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Mar 20, 2011 | Bosch SHU9955UC Built-in Dishwasher
Food always gets stuck in the water spray holes pluging them up. It needs a better food filter system. We have a GLD4500N
As recommended most of the dishwashers are not equipped with this filter. But it is always recommended to clear the food off the dish/plates, wash off or wipe and put it for cleaning. The dish washer cleaning is entirely the degreasing/ sterilising of the vessels.
Hence the tip to get your dish washer in good shape is to wipe/wash off the food and load it to the trays inside.
This is my suggestion as we cannot improvise the machine. I hope this helps Good day
Aug 18, 2010 | GE 24 in. GLD6300L Built-in Dishwasher
Dishes are not clean and white residue is left on dishes
clean the filters or get new ones.make sure your water in is connected to the hot water not cold.Also put new rubber O rings on the spinning arm water sockets.
Jul 20, 2010 | Maytag MDB5100A Dishwasher
Film on dishes
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 12, 2010 | Tappan 18 in. MDR251RE Built-in Dishwasher
Dishwasher is leaving grit and dirt on dishes. I have cleaned filter, but nothing changed.
run a load without dishes and see if it drains properly if not your drain hose is pluged or its not draining properly
Aug 23, 2009 | Dishwashers
My glasses are net getting clean, this just started to happen. What can the problem be?
The most common reason for dishes (especially glasses) not getting clean is the dishwasher's heating element has failed.
When the heating element does not turn on when it should, the water is not heated enough to activate the dishwasher detergent.
Also, if you have recently started to use a new box of DW detergent powder, if you bought the cheap kind, that could cause problems, but normally that leaves white marks on the glasses, not a dirty film.
Aug 05, 2009 | Dishwashers
Dishes do not come clean grit on them
either dirty wash arms of insufficient water
Feb 24, 2008 | Frigidaire 24 in. PLD2850 Built-in...
587 Doesn't work well
AS ABOVE SUGESTION ...PROBUBLY NOT GETTING ENOUGH WATER. NOT LIKELY THE FAULT OF THE DISHWASHER PROBUBLY SEDIMENT FROM THE WATER PLUGED THE INLET SCREEN OF THE FILL VALVE. MANY TIMES THE MOVING OF A FLEXIBLE PLUMBING LINE BRAKES LOOSE ANY SEDIMENT AND DEPOSIT DURING THE INSTALATION OF A NEW DISHWASHER WHICH IS WHY MOST ADVISE REPACING THIS SMALL FLEXIBLE LINE WHEN INSTALLING A NEW DISHWASHER. YOU WILL HAVE TO DIS ASSEMBLE VALVE TO CLEAN SCREEN ...IF YOU BOUGHT THE PROTECTION AGREEMENT OR HAD SEARS INSTALL IT THEY SHOULD COVER A SERVICE CALL TO CLEAN THE VALVE.
Jan 24, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher
Go to www.dishwasherfilter.com and have sparkling clean dishes with no film or spots, every time!!!
Make sure you use promo code DF5150 to get an additional discount!
Nov 14, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dirty dishwasher
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Sep 24, 2007 | GE 24 in. GLD5500L Built-in Dishwasher
Bosch Integra® 500 SHX46L Built-in Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
