Question about Belkin Wireless Router
Blue wireless light wont come on, so I dont have wireless interne
My router is hooked up to my charter modem, everything is working fine, except the blue light showing I have wireless wont come on, so I don't have wireless. I've restarted my computer 4 or 5 times, I've unplugged the router and plugged it back in, the same with the modem. Help!!! Any help will be appreciated.
Thanks,
Charlie
  • 550 Answers
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Posted on Jul 14, 2010
Hello, I am currnetly using a Belkin ADSL2+ modem with wireless G Router and have just been given a D-Link Dir-855 Xtreme N Duo router I wish to use and have been told I can buy a ADSL Modem only to...
I think there is no need to replace the ADSL2+ Router.
Belkin is fine and should work well in combination with the D-Link Router and you would get the downlink data rate up to 300Mbps.
I recommended that you use Belkin Router as ADSL Modem and Dlink to provide wireless access. (Instead of buying ADSL Modem)
So, all you have to do is : -
-Turn-off wireless signal of the Belkin modem.
-Connect the Dlink Router to the Modem (Belkin) through CAT6 Cable.
-Configure the Dlink Router, Secure it and Enjoy 300Mbps Data Rate.
(In this way your Belkin will serve as ADSL Modem and Dlink would be the wireless router)
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
May 09, 2011 | D-Link Xtreme N Wireless-N Gigabit Router...
Just had cable Internet installed and have had problems with it disconnecting every night at the same time, SB5101N Motorola. I have a wireless router, Belkin F5D8236-4, and was previously hooked up to my...
As long as your laptop doesn't have a firewall enabled then you should almost always be able to get connected by directly connecting your unit to the router.
Here is how to Determine if you Windows Firewall is enabled
Once it is disabled try resetting your Belkin back to Factory default Settings.
If all that still doesn't work I would attempt attaching it to the modem, and know once and for all if you router is working correctly.
Hope this help, and if it did please remember to leave Feedback/Testimonial. Thanks.
Mar 21, 2011 | Arris SURFboard® SB5101 Cable Modem
My Wireless-G Broadband Router was working fine until yesterday when I lost the connection. I have tried everything I know to do to get the connection back. I turned off all the computers; the modem, and...
If you can access the configuration page of the router then check the IP configuration. Check WAN and LAN configurations. IP 192.168.1.1 or 192.168.0.1 will able u to access configuration page. Username and password hopefully be admin admin.
Regards;
Hasan
Dec 27, 2009 | Linksys Wireless-G Broadband Router
I have charter internet with a modem and i have a westell 327w wireless router/modem. How can i connect the two modems to work wirelessly?
I think the Westell Router/modem that you have must be the modem for the DSL connection.
Charter is a cable internet service provider.
You can not use 2 modems connected to each other.
You have a charter modem , you can purchase a wireless router only.
That will work.
Click Here for more info about routers
Oct 27, 2009 | Westell Wirespeed VersaLink...
Router Wont COnnect To Internet
Reboot your modem, router, and computer. Power them all down (unplug the modem and router if necessary) then boot the Modem, then after a minute boot the router, then your PC and see if all is well, it should be.
Jul 24, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Belkin N router reads everything but the computer.
If your router was working before, and suddenly stopped working, then you probably need to reset it.
Unplug the router from power, also unplug all network cables from it.
Wait about 30 seconds.
Plug power back in, followed by network cables.
Wait some more seconds while the router restarts.
Only the Power light and the Status light should be solid.
All others in use must be blinking, which means they are in use.
Try connecting to the internet with cable first, then try wireless.
It should work.
Please don't forget to rate if answer is helpful
Jun 22, 2009 | Acer Aspire 5050-3242 Notebook
Belkin G Wireless Router Connection problem
Sounds like a faulty router or issue with the firmware if it is unaccesible, your best solution is to factory reset the device and try again.
Regards,
Kris
Mar 17, 2009 | Belkin (F5D7230-4) Router (587009)
Siemens SpeedStream 6520 Wireless problems! please help
um not sure, but if you have the disk that came with your router run it and fill in the wireless wizard. Also, on my 6520 the "wireless" led doesnt light up unless i have a device connected that is wireless. Your laptop may be incorrectly setup
Jun 25, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Cable modem
Go and buy a router. Plug your existing modem into the WAN port and your computers into the LAN port. You could even get a wireless router and connect your upstairs computer wireless. Be sure to lock down your SSID (Wireless Access Point Broadcast Name) so your neighbors or people driving by don't get on and do bad things on your network.
May 31, 2008 | RCA Cable Modem DCM315R (11603540)
Belkin Wireless Router Logo
157 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
