Question about Garden
I have a 2-gal lawn&garden sprayer w/ irreguler spray pattern spits w/ spraying
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details of the problem.
Thanks.
Posted on Jul 21, 2010
Just bought the Ace 2 gal poly deck sprayer but it will not spray just puts out a stream of stain..is there something extra I should have purchased to get this to spray ??
I had the same problem. The deck sprayers are meant for thin liquids, not the heavy stains. Some stains have a thin consistency, others are thick. You can go back and buy a thinner agent for your particular stain, but , in my experience doing that, it thinned it too much, the color was off and didnt cover right. I ended up using a roller and brush to do the job right.
Sep 19, 2011 | Ace Hardware Ace 2Gal Home and Garden Poly...
Just brought new ortho spray home from lowes. followed all directions and it will not spray. not very happy!
I am sorry to hear about the problems you are experiencing with your sprayer. We do have replacement sprayers available. Please give Ortho a call at 800-225-2883. Hilary @ Ortho
Jun 18, 2011 | Ortho Home Defense Max Insect Killer 133...
Sprayer spits while spraying
When that happens it is usually because you have dirt in the nozzle or it has not been clened properly.
Replace the nozzle or clean it...
heatman101
Jul 13, 2010 | Gilmour Garden
Pump is presurized but no spray
Most weed killers and fertilisers either crystalise or turn to gel when left unused. Pull sprayer wand to pieces and run hot water through the hose and wand, they especially clog up at the spray tip and at the on'off control.
May 14, 2010 | H.D. Hudson 1 Gal Poly Deck Sprayer
Pressure no spray on 1 gal tank
try removing the tip and cleaning it. there maybe something stuck in it even if its new. if that dont work i would take it back to where i bought it. hope that helps
May 16, 2009 | Garden
Sprayer is spitting instead of spraying, why?
Either the fluid you are attempting to spray is too thick or the little holes in the spray head are partially clogged. Begin by running some small copper wire thru each hole to unclog it and see if that solves your problem. If not, filter the liquid you want to spray and dilute it as needed.
Apr 15, 2009 | Garden
Instructions for using ortho tree sprayette
The Ortho Tree and Shrub Sprayette has a fixed mixing jet set to a 24:1 ratio. 5.3 ounces of spray concentrate in the jar will mix to produce 1 gallon of diluted spray. The jar has a capacity of 42.7 ounces, so you can spray up to 8 gallons with 1 filling. If you look at the side of the jar, you will see two filling scales. On the left is the diluted spray capacity, and on the right is the concentrate scale. So you will see 8 gallons opposite 32 ounces, for instance.
You must dilute concentrates to the 24:1 mixing concentration. So if your concentrate says 1 ounce/gallon, and you want to spray 6 gallons, put in 6 ounces and add water to the jar to the 32 ounce level.
Mar 16, 2009 | Garden
Sprayer tips
Read and FOLLOW EXACTLY the spray material directions for mixing and use. Wear protective clothing including gloves and eye protection when spraying. Do not smoke, eat or drink when spraying; "wash up" afterwards. Spray on a calm day. Otherwise, winds may blow spray material off target. It's often best to spray in the early morning or late afternoon so excessive heat won't quickly evaporate the spray material. Follow the directions for use and maintenance that come with your applicator. Dispose of left over spray material and clean your applicator according to the directions on the spray material and with the applicator. Keep spray materials and applicator away from children and pets. Do not store spray materials in any but the original container in which they were purchased.
Aug 27, 2008 | Ultra Max R. L. Flomaster Atomist Electric...
Garden Logo
22 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
