Question about Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis He stopped in mid cycle, leaving about 5 inches of water. It now will not restart and the water remains in the tub. The power had gone out prior to this happening.
  • 1,284 Answers
Hi, i think you have Error Ld problem which means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine, if not then it should be replaced.
Take care
Posted on Jul 13, 2010
  • 2 more comments
  • spw320 Jul 13, 2010
    How do you check the drain pump? Where is it located and how do I find it?
  • Shehu Pro
    Shehu Pro Jul 13, 2010
    It's behind the washing machine, you have to uncouple it to gain access.
    I have no knowledge of these machines and so request that you answer as though talking with a novice (me). Thanks.
    I removed the back and still don't know which is the pump or how to check to see if it is working. Can you be more explicit.
  • Shehu Pro
    Hi, the drain pump is located at the base of the large laundry tub. A wide drain hose snakes away toward the back of the machine and an electrical connection.
    Place a container or shallow pan underneath the pump. Use pliers or your fingers to squeeze the clamp holding the drain hose in place. Allow any water to drain into the pan and remove the pump from its fittings.
Kenmore elite model 11027052602 clothes wet after spinning cycle why
You might have a restriction in the outlet hose. Worse, you might have a bad pump.
It is easy to check for the constriction. Pour water into the tub, set the timer for the spin cycle and watch how strong/fast the water leaves the hose. Check for water beneath the tub.
Oct 07, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Unbalanced load stoped it mid cycle no codes shown how do you restart
Normally you re position the load until it is evenly distributed around the tub. Close the lid and press resume or restart.
Aug 17, 2013 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
The Dryer is working but stopped in mid cycle and gave me a code of PF
Power Failure. Press and hold start to restart dryer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 04, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
70 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
