Question about Technics Audio Players & Recorders
Unit shuts off when warm, after about 10 minutes turns back on. How do I fix this?
  • 336 Answers
Check for bad solder connections on the voltage regulators. they are located on the heat sink on either side of the output ic. may need to resolder the output ic also.
Posted on Jul 15, 2010
TAKES 45 MINUTES TO COME ON
Evidently there is an internal power supply problem.
Nov 12, 2013 | Televison & Video
Similar situation as previously described with the Denon AVR-1508, but mine will shut off after about 10-12 minutes the first time around and then ~2 minutes after it is turned off and then back on. Unit...
Most new receivers have a fan on the back, if you have one check to make sure it is working, most won't activate until the unit gets warm, other issues are bad solder connections on the audio outputs causing intermittent shutdown, as a final inspection check speaker connections to the receiver and speakers.
Sep 18, 2011 | Denon AVR-1508 Receiver
I have a glow warm 20000 btu natural gas unvented heater. The unit is wall mounted. It won't stay on for more than 15 minutes, then shuts itself off. Its in a corner if that makes a difference... but has...
well, these heaters are typically thermostat-bound, and I have found that they simply will not burn continuously, like a blue-flame heater. Try turning up the setting--this will make it come on/off more often, effectively heating at least one med-lg room, and partially for adjoining areas. Keep in mind that these only rated for 700-1500 SF--that is NOT the floor measurements, but square feet of airspace; eg., a 10' x 15' room has 10' x 15' x 8' (8 foot ceiling) =1200 sf. That said, My 15k btu wall unit had been the sole heating source for my entire home for 5 years, until last year, when I acquired another smaller unit. However, I typically only use a few rooms, and shut off unused areas (ya, was 'cool' in unused back room areas).
Dec 16, 2010 | Desa International GWP20T GLOWARM Wall...
My TV won't stay on until it's warm?
have your unit power supply check, maybe some cold solder or leaky capacitor is the culprit.
Aug 01, 2009 | Philips 42PFP5332D 42 in. Plasma...
2004 s40 volvo-ac works for 10 minutes then gets warm.
evaporator leaking or condensor fan inop
Jul 31, 2009 | 2004 Volvo S40
My oven does not shut off.
Hi there, this is a serious control fault that may be fixed by unplugging this unit for a five minute period. after this hard reset, plug the unit back into the wall outlet and power up. if the unit continues to stay on, you will need to replace the control(electric oven control)board.
May 18, 2009 | GE Kitchen Ranges
Unit Always Shuts Down While In Use
all the laptops on the world have warm problem. if you use your notebook dirty place your fan could get dirty and not working well and not makes cool anymore. in warm system can shut down itself. it is often does. if you open your laptop back case you will see the fan. there are olny 4 screw. clean the fan and screw again. try it.
sorry for my enghlish.
May 17, 2009 | Acer Aspire 7720 Notebook
Shuts down during warm up
the fuser unit is not warming up, so the machine shut down
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 21, 2009 | Xerox Office Equipment & Supplies
Unit shuts off after being on for 10 minutes or less
you will need to call a repairman to come in and fix the set...too bad about the warranty though would have come in useful
Jan 24, 2009 | Toshiba 51H84 51" Rear Projection...
56 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
