Question about LeapFrog Leapster 2 Learning System
Wont go past warning screen
My sons leapster 2 will turn on, but after if goes to the warning screen it shuts itself off again. I have tried to replace the batteries and even plugged it directly into the wall with no success. Any tips?
  • 3 Answers
SOURCE: Our brand new leapster2 has
you could try this....
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Posted on Feb 07, 2009
SOURCE: Leapfrog Leapster touch screen
Press the ? button and hold it while turning unit on.
Press the "a" button to select touch calibration
Press each + with the stylus
Restart machine
Posted on Apr 19, 2009
SOURCE: Leapster 2 will shut off right after the "important" screen
Are you using it with a game? Will it stay on if NO game cartridge is in & are U able to access & play Pre-installed games?
If so, it may be the cartridge is DIRTY. I discovered this with our Leapster 2. What works for us is getting a Q-TIP & RUBBING ALCOHOL, you want to saturate Q-tip with the rubbing alcohol & clean the CARTRIDGE (NOT the Hand held ).
You want to clean the computer chip @ the bottom by inserting Alcohol soaked Q-tip on each side of contact strip (the part that inserts into the hand held) & with the dry end of Q-tip go over it again, for more cleaning & to wipe up any EXCESS Alcohol. REPEAT this process until Q-TIP comes back CLEAN.
I was really surprised @ ALL the BLACK grime that came off cartridge.
I hope this helps.
Good Luck.
-The Johnson Family :-)
Posted on Jun 18, 2009
  • 12 Answers
SOURCE: The sound on my sons leapster 2 has stopped
1.You can get a full refund 2.you can contact customer service 3.buy another one whith your refund:)
Posted on Oct 15, 2009
  • 3 Answers
SOURCE: We have a Leapster 2 less than 1 year old. It
We have the same problem and our leapster is only 2 days old.Do Touch Screen Calibration,it should help.I do it everytime for my son when he wants to play and it does help...But once u turn leapster off,u'll have to calibrate it again next time...
Just hold down hint button while turning on.When the Leapster menu screen appears,press the A button.Touch each of the crosshairs that appear with the stylus.restart unit. ..That what we do everytime.
Posted on Dec 05, 2009
The pen on my sons leapfrog leapster won't work
Push the "A" button to enter the calibration.
There will be a little plus sign. Touch it with the stylus and continue to touch the plus signs with the stylus until you return to the calibration screen.
Turn the Leapster off and then back on again without a cartridge.
Sep 05, 2012 | LeapFrog Leapster 2 Learning System
Leapster wont switch on
if the light goes green for a very short period before going red again it means theres a short on the circuit board. u can try and find the problem but because the circuitry is very small, it wont be easy to find. only other solution is to buy a new circuit board :(
Dec 25, 2007 | Sony PlayStation 2 Slimline Console
The Leapster turns on and the sign in screen comes up but the touch screen does not work. Recalibrating does not work. Can't get past the sign in screen
How did you try recaibrating? I just fixed my son's Leapster 2 a few minutes ago. I read a couple different recalibration instructions and the one that works for the Leapster 2 is:
1-Hold down the (?) Hint button while turning on the system.
2-Keep holding it down until the Leapster menu shows up
3-Let it go and press the A button
4-Touch each crosshairs x with the pen tip
5-When it goes back to the menu screen, restart the unit
Jan 21, 2011 | LeapFrog Leapster 2 Learning System
Leapster 2 wont work
You need to calibrate the touch screen - hold down the ? button and a menu will come up, go to 'touch/calibrate'-red dots will appear on the screen in the corners then in the middle and you have to touch the centre of them with the pen to line up the screen again - turn off and again and it should be fine - hope this helps xx
Jan 04, 2010 | LeapFrog Leapster 2 Learning System
Dec 03, 2009 | LeapFrog Leapster 2 Learning System
TOUCH SCREEN IS NOT WORKING
Oct 24, 2009 | LeapFrog Leapster 2 Learning System
My son has a leapster 2 but cant play anymore..........
check your CPU whether it has space behind it for proper working of fanOR put a new ram
Mar 26, 2009 | Leapster Learning System
Jan 21, 2009 | Leapster Learning System
Leapster 2 Doesn't Recognize Stylus
Hold the hint button (question mark) when turning on the device. When the device turns on, do the stylus calibration and touch each of the crosshairs that shows up. After you are finished restart the leapster and you should be fine.
Jan 03, 2009 | LeapFrog Leapster Electronic Book:...
LeapFrog Leapster 2 Learning System Logo
382 people viewed this question
Top LeapFrog Toys Experts
thegtw
relojmesa
GI Consulting
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
