Question about Philips 42PF5321 42 in. EDTV-Ready Plasma Television
Fuse 8 amps 250 volts for Phillips flat screen tv
Need a fuse location number f8001. Fuse t8ah/250vp
  • 4,889 Answers
Is it a pico fuse or ceramic glass type fuse?
Posted on Jul 13, 2010
Phillips 50" Plasma, Fuse F8001 blows after a period of time on Power Supply.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Apr 10, 2016 | Televison & Video
Toshiba 37E200U LCD television
T5.0AH 250V used in this TV is a ceramic fuse Time delayed (Slow-Blow) and the dimensions are probably: 5 mm (3/16 in) x 20 mm (3/4 in). You just measure the old one.
Regards GJ
Jun 20, 2014 | Toshiba 37E200U 37 in TV
Samsung dishwasher no power/display off
The Samsung DMR57LFS Dishwasher has a 15 Amp/250VP Volt Fuse located on the lower right side of dishwasher behind an aluminum panel held by two screws. Pull dishwasher out from counter, remove lower rectangular aluminum panel, and it is just inside underneath. Unscrew fuse holder and replace fuse. I had to pay a Samsung Authorized Repairman $109.70 to replace a simple fuse. I learned the hard & expensive way. Samsung won't tell you to check the fuse underneath the unit. They won't even tell you that there is a fuse underneath on the right side. The fuse protects the Printed Circuit Board or Blue LED Control Panel in the event of a power surge or lightning strike.The less than $4.00 fuse will blow first.
Jan 27, 2013 | Samsung DMR57LFS Stainless Steel Builtin...
Fuse blown on incoming power replaced fuse but no luck
replaced the t8ah 250v fuse and it still blow when i turned on the tv
Oct 19, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Where is the fuse in a 3701 LCD Polaroid TV/Monitor
In the Polaroid FLH-3701, the fuse is located on the power supply board, next to the AC power connector. It is a small black cylinder. It is labelled F1. Value is 5 amp, 250 volts.
A fuse does not blow for no reason. Most commonly a fuse will fail because of a short someplace on the board. I have this same TV. The fuse blew. The reason was transistor Q6 had shorted. There are two identical paired transistors on the output side. Q6 and Q7. They are both Infineon 11N60C3 MOSFET transistors. Check those for a short. There may be a burnt smell.
More commonly, this TV will fail because of bad capacitors on the power supply board.
May 08, 2010 | Polaroid FLM-3701 Television
I have a Philips 42" Plasma that will not power up, blown T8AH
http://www.newark.com/littelfuse/0215008-mxp/cartridge-fuse/dp/42K9308
Fuse is a "Littelfuse 0215008.MXP"
8A 250V Slow-blow ceramic
Jul 29, 2009 | Toshiba 50HP95 50 in. Plasma Television
Panasonic TH-42PX600U plasma TV. No power at all. Where is the fuse (if any)?
I'm having the exact same problem. My Panasonic 42 inch TH-42PX60U just turned off while I was watching TV. I removed the fuses (both were blown) and replaced them and am now getting the red light that blinks ten times.
What should I do now???
Thanks!
Abbie
abbie.bejrowski@gmail.com
Nov 10, 2008 | Televison & Video
My phillips 42" flat screen model number 42pf7621d/10 keeps blowing the fuse in the plug usually after we have turned the tv off and its in standby mode or overnite when we sleep ive just change...
What is rating of fuse in your TV like amperes and volts.
There is Thermistor in TV for degaussing the picture tube while in start up. This part requires heavy current to work for a second or two.
You can increase little bit current rating of fuse to avoid blow off.
Oct 01, 2008 | Philips Televison & Video
Samsung Flat Screen Won't turn On
yea take your tv to a tech tv has a problem in the power supply there is 10mf cap in the power supply that likes to go bad replace it if that model does not have it check regulator and the microchip.however your problem lies in the powerand related circuit.good luck
Apr 02, 2007 | Samsung TXN3275HF 32" TV
Philips 42PF5321 42 in. EDTV-Ready Plasma Television Logo
344 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
