Nikon COOLPIX L18 Digital Camera Logo
Posted on Jul 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I PUT IN A NEW MEMORY CARD FOR MY COOLPIX L16 AND WHEN i TURN ON THE CAMERA IS SAYS CARD NOT FORMATTED. FORMAT CARD? NO YES I have also tried to import the pictures onto my computer and it saysThis card cannot be used. Have I lost my pictures?
  • Anonymous Jul 13, 2010
    I'm confused...is this a new card or is it a card you've been using and now you're getting a message that it needs formatted?
Anonymous
Level 2:
Guru:
  • Expert 285 Answers
  • Posted on Jul 13, 2010
Anonymous
Expert
Level 2:
Guru:
Answers
285
Questions
0
Helped
88651
Points
770
Dude ur memory card is corrupted need to buy new one sorry cant do anything for recovering data from a dead card
Camera wont read the disk
Coolpix cameras do not have a disk; they use an SC memory card. When you put a new SC card in the camera, you must format it before you use it. Go into your camera's Menu. Under Setup, you will find "Format memory card". Once your SC card is formatted it should work.
My nikon coolpix p2 camera says this memory card cannot be used, but it is a new memory card.
Have you formatted the memory card? When you buy a new memory card, you must go in your camera's menu and find the "format memory" selection and perform the format function. Once formatted by your camera, it should work.
1helpful
4answers
I found one in my desk at work. It's missing a memory card thus no one is using it. What kind does it take? Can it be by any brand?
It can take a SD memory card or SDHC memory card, recommended brands: SanDisk, Toshiba and Panasonic from 128 MB to 4 GB capacities.
The manual and other information for the Coolpix L18 is available from Nikon: http://www.nikonusa.com/Nikon-Products/Product-Archive/Digital-Camera/25596/COOLPIX-L18.html . The list of memory cards is on page 91.
I hope this helps.
2helpful
2answers
Put a new 4gig card in as I lost the old 1
I verified that I cannot format my 4 GB cards in the Coolpix 5700. This camera simply cannot use large memory cards. You should get a 1 GB card for this camera (I verified that 1 GB cards do work).
1helpful
I bought a used e5400 i put a new card in it and it reads out no memory available
Hello. You must format your new card before the camera can read it. Just go into the menu and find format. click on it. it will ask you yes or no and push yes. Regards, Joe
3helpful
My sony dsc-w100 digital camera says format error and hangs on. what shall i do??
Take out memory card from camera, turn it On and check does it show format error?
If yes, press Home, Memory option and format internal memory.
If camera does not show format error then put back memory card in and press Home, Memory card option and format it.
This will delete all files/ data and will refresh memory card, take some pictures and check.
If after formatting, still format error exist, put new memory card.
1helpful
Cannot find instructions in manual for Nikon Coolpix S210 on how to delete ALL photos from memory disk. It will let me delete one at a time but I want to wipe the memory card clean. Thanks for any and all...
These instructions are from the Instruction Manual of the Coolpix S 210 and need to be carried out within the Set-Up Menu.
Refer Page 19:
Removing Memory Cards
Before removing memory cards, turn the camera off
and confirm that the power-on lamp is off. Open the
battery-chamber/memory card slot cover and press the
card in 1 to partially eject the card 2. The card can
then be removed by hand.
B Formatting Memory Cards
If the message at right is displayed, the memory card must be
formatted before use (A110). Note that formatting permanently
deletes all pictures and other data on the memory card. Be sure
to make copies of any pictures you wish to keep before formatting
the memory card.
Use the multi selector to choose Yes and press k. The
confirmation dialog will be displayed. To start formatting, choose
Format and press k.
Do not turn the camera off or open the battery-chamber/memory card slot cover until
formatting is complete.
• The first time you insert the memory cards used in other devices into the COOLPIX S210, be sure to
format them using this camera (A110).
Refer Pg 110:
 Format Memory/m Format Card
Use this option to format the internal memory or a memory card.
Formatting the Internal Memory
To format the internal memory, remove the memory
card from the camera.
The Format memory option appears in the setup
menu.
Formatting a Memory Card
When the memory card is inserted in the camera, the
Format card option appears in the setup menu.
Hope this helps
Ian
1helpful
2answers
this memory card not formatted error is quite famous, I saw it before, but luckily I found the solution, check it out
Fix Memory card not formatted error and recover files
hope that you can find the help as me.
Nikon coolpix L18. Can't put pix on comp. format card
I suggest you to remove the card from the camera and use a memory card reader to transfer the pictures to the computer. Note that the memory card should be formatted in the camera. Once the pictures are transferred you can reinsert the memory card to the camera and then format it in the camera.
1helpful
2answers
Nikon coolpix 885 out of memory
if you formatted the memory in the camera, and the camera can not see the available space, then you have a non-user serviceable issue. send to nikon. you can call them for online assistance, however it is unlikely you will get a different answer.
good luck
mark
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
