How do i fix my blurry fonts problem on the computer ? i reformat my computer and there are blurry fonts.
    Guru:
  • 285 Answers
Fonts ar blurry because u had selected incorrect screen refresh rate select proper config right click on desktop goto properties now display property dialog will be show click on settings click on monitor change trefresh rate select 60 hz if res is n1024x768 or more and 85 if its 800x600 or less
Posted on Jul 13, 2010
Would like to change font colors on my chromebook
The font changes need to made under settings, then advanced settings. See this Google webpage.
Change text image and video sizes zoom
Sep 17, 2014 | HP Pavilion 14-c010us Chromebook 14-C010US...
How do I shrink desktop icons, window tabs, font?
try to higher your resolution(right click, properties),if it does not solve your prob. i think you mess with the video card installer. install the video card installer again. About your icon dont worry it will return to its place after you get back your resolution.
Mar 30, 2010 | Microsoft Windows XP Professional
My daughter played toontown and when she quit it completely changed my screen resolution and blurred out my screen fonts. I fxed the resolution but now the fonts on my desktop are permanently blurry.
try updating your graphics card drivers, if that doesn't work, try restarting the computer, going into advanced boot options, and then, first select last known good configuration, and if it doesn't work... try using system restore... if that doesn't work as well, it means, that a startup program might be at fault, try this..
http://support.microsoft.com/kb/310353 ...
Good luck with the steps..
Nov 22, 2009 | Disney Interactive Disney's Toontown...
Sent messages are blank
try to used another computer atlest two computer if the same problem...if working in another computer it means the operating system have a problem about that maybe infected of viruses or something wrong.... make reformat your pc or laptop....
May 25, 2009 | Yahoo Mail
Fuzzy/blury fonts on a samsung syncmaster 920nm
Good morning! Please review/check the set-up settings of your samsung flatscreen, best to refer it to the operations manual of the monitor which should be included when you bought it. best regards.
May 02, 2009 | Samsung SyncMaster 920NW Monitor
Windows Vista
What you need is Disable and Turn Off ClearType Fonts in Windows Vista
Windows Vista by default applies ClearType effect to the fonts displayed on screen, in order to improve the appearance of text on certain types of computer display screens, especially LCD flat-panel monitors. As ClearType text actually sacrifices color or chrominance details aspect of image quality for light and dark or luminance detail, some people may not like the blurry font style in ClearType. Here’s a easy way to disable or turn off ClearType in Windows Vista.
1. Right click on any blank spot of desktop, and then select Personalize on pop-up context menu.
2. Select Window Color and Appearance.
3. Click on “Open classic appearance properties for more color options” link located at the bottom of the page.
4. Click on the Effects button.
5. Do one of the following:
Uncheck (untick) the “Use the following method to smooth edges of screen fonts” box.
or
Select “Standard” to replace ClearType in the drop down list under the above title.
6. Click OK, then click Apply, and finally finish with clicking OK again.
To enable or turn on ClearType effect again, simply reverse the setting in the Effects step.
< Please Rate :) >
Apr 12, 2009 | Compaq Presario R3000 Notebook
How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Mar 08, 2009 | LG Flatron L1750S 17" LCD Monitor
Westinghouse LVM-37W3SE PC Monitor
1. Genaraly 14" and 15" Monitors supported Up to 800by600 some monitors 1024by768pixels 17"monitors supports 1024by 768 to 1280by960 pixels and Other 19",21" are supported 1280by1024 pixels at the same time change the screen Refreshrate at display properties.
Oct 01, 2008 | Computers & Internet
Acer AL2216Wbd blurry
get it checked that a problem with the monitor also check it on another monitor if you can
Nov 20, 2017 | Acer 19" LCD Monitor
Computers & Internet Logo
140 people viewed this question
Alun Cox
David Payne
David Payne
