Question about Koss KS4192 System
When we first start the unit, it has gotten quite a loud whirring sound. We turn it off, then turn it back on and the noise virtually disappears - it's still there, but greatly diminished. I suspect something like a worn drive band, but haven't had the unit apart yet to see. Any hints?
  • 3 Answers
That is the fan on start-up and the high pitch is the power supply components heating up make shure that the main fan is working always it will be slow at low volume if it quits you run the risk of the power supply failing
Posted on Jun 18, 2011
My Toyota corolla has been making a loud whirring sound on top of the normal engine sound, tends to go when it is warm. Oil light came on intermittently the other day and the sound changed but no oil
My truck Hino dutro year 2005 is on check engine light, coputer say this fault, p2002 particulate trap efficiency below threshold (bank 1) now i dont know what is this fault Plz send me detail for this fault and solution.
Feb 07, 2013 | 2005 Toyota Corolla 1.6
My LG fridge model LFC 23760 ST is 1 yr old and has started noises when compressor kicks in. The whirring of the fan has gotten quite loud. Any ideas?
It could be that the cooling area is being restricted by something. Remove the front panel and take a look to make sure everything looks ok. You should have a warranty and I would sure use that before you have more problems...
Sep 22, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
I dog motor makes a whirring noise
Sounds like this is an problem that cannot be repared. I would say return it but its to late. You should replace it. Or try manually taking it apart and fixing it back. =]
Jul 28, 2009 | Hasbro I-DOG AMP'D
Loud spin cycle
OTHER THEN CHECKING THE WATER PUMP I THINK YOUR RIGHT THE BEARING ARE GOING,IT WILL WORK FINE TILL THEY LOCKUP THEN THE BELT WILL BURN OFF,BUT I WOULD CHECK THE WATER PUMP ALOT OF TIMES IT JUST THAT,LET ME KNOW -MIKE
Nov 03, 2008 | Frigidaire FTF530ES
GE SidexSide PSS26SGPASS Makes Humming Noise
GE refrigs have a variable speed evaporator fan motor that is controlled by a computer board on the back of the refrig. now the noise you are hearing is most likely the fan motor ramping up and down in speed (some of my customers say it sounds like a ghost). if its a continuous ramping up and down then the speed cotroller on the board is bad and must be replaced. if its just an occasional sound then thats normal and nothing to worry over.
Btw the reason the noise stops when the door opens is because the fan shuts off when you open the door.
Dec 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud whirring. Not the fan.
The fan noise is normal on this set. The lamps are cooled via this method. Your users manual explains this issue..and it is the fan as you can see it slows down after the tv is switched off..
Oct 20, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Whirring noise. No other problems.
Sounds like you have a noisy color wheel. Very common on all Samsung DLP`s. The part # is BP96-00250A for model HLN5065W.
Oct 16, 2007 | Samsung HLN5065W 50" Rear Projection...
Koss KS4192 System Logo
80 people viewed this question
Top Koss Audio Players & Recorders Experts
Steve Allison
Steve Allison
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
