I have a Viore 20'' TV about 3 or 4 years old. It will not turn on with either the remote or the power button on the TV. It worked just fine until two days ago. I have checked all power connections, and all seem ok. Can you help?
  • 4,889 Answers
What is the model no of the tv? Is it a CRT or a LCD tv? What is the status of the power LED at the front? Sounds like a power supply related issue but just to be sure please provide the info requested so that we can continue with the diagnosis.
Sai.
Posted on Jul 13, 2010
Viore tv sound cuts out
Could be a failing power supply
Mar 12, 2014 | Televison & Video
I have a Magnavox TS2760 C101 Television that is 15 + years old. We have Dish Network witht he original remote. It has stopped controlling the TV. It was working fine, then quit. Dish does not have the...
Hello! I came across your post, and think that I can be of some assistance. These are the codes that we have for Magnavox, and steps to program the remote. I hope that they help!
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
566
560
829
or if that doesn't work, here are the instructions for a power scan, which doesn't use codes. The remote scans the TV for the correct code.
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
Mar 02, 2011 | Philips Televison & Video
Viore 42" plasma tv has
The tv was working fine until this morning, then the picture went out but the sound is still working.
TV is only 3 years old, no real electrical problems
Jan 29, 2011 | Toymax Viore 42 in. Plasma TV
Dish remote code for Viore 32" HD LCD
Hi, my name is Cheri Torres and I am with DISH Network customer service. I came across your post and wanted to see if I could help. DISHNetwork remotes have a few different codes for each of our different models of remotes.You should be able to find your remote model number on the back at the top ofyour remote it's usually a two to three digit number with a decimal point. Iwill list here for you the best codes for the most common DISH remotes and alsothe instructions for addressing your remote to your TV. The only codes that I was able to find for the Viore TV were for the 5.3 IR remote and the codes are 563 and 500. If these codes do not work you can also try running a channel scan to find your particular code. I will also list here for you the instructions for running a power scan. I hope you find these codes and instructions useful and if you have any further questions or concerns feel free to post back here or email me at Cheri.Torres@Dishnetwork.com. :)
Instructions for addressing remote to TV,
  1. Turn the Television On
  2. Press and Hold the TV mode button down until all the mode buttons (i.e AUX, SAT, TV etc.) light up.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Instructions for running a power scan
  1. With the desired equipment on, press and hold the TV button down until all the mode lights light up.
  2. Press 500 using the number key pad.
  3. Press the pound(#) button once.
  4. The TV button will blink red three times.
  5. Then again press and hold down the TV button down until all the mode lights light up.
  6. Press and release the big red Power button once.
  7. Press the Up button once every second while pointing the remote at the desired equipment. Keep pressing the up button until the TV turns off until.
  8. AS SOON AS THE TV TURNS OFF Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
  9. Try the functionality of the TV to see if the power scan worked.
Nov 29, 2010 | DISH Network IR Remote Control
I have a viore tv dvd combo need codes for it
You probably have the same problem that I found after I'd purchased my Viore TV (LC 26VF59), your cable box remote or dish network remote doesn't have the Viore codes built in. Bummer. I looked around and couldn't find codes for my Viore. Doubt you'll find them for yours. Here's a helpful suggestion I read about that works for me:
I bought for $20.00 a Sony RM-VL600 Easy Learn remote control from my electronics store. It's EZ because you only have to place the Sony head to head with the Viore remote, press TV setup and follow Sony's instructions to have its remote catch and learn the codes from your Viore remote. I only programmed my Sony for the Power On/Off, Vol Up/Down from my Viore remote. You back out of Setup and now your Sony will control the TV for those functions. Next you get your cable box or satellite remote put it head to head with the Sony remote, press the CABLE or SATELLITE set-up button on the Sony and then have it learn all the C or S functions you want from that remote. You do program in this mode the Power On/Off button, but you don't program the Vol Up/Down. The volume for the TV will work when you're all finished and operating under the Cable or Satellite button on the Sony remote.
Now, you press the TV button on the Sony and then the Power button. The TV turns on. Now you press the Cable or Sat button and then the Power button and the Cable or Sat box turns on. Like I said, even though now you are operating the Sony remote under the Cable or Sat button the TV volume instructions carry over to this side of the remote so you don't have to switch back to the TV button to raise or lower volume of the TV.
When I'm done watching, I hit the Power off and the cable box turns off. I then hit the TV button and again the Power off button and the TV turns off. So, it's a little inconvenient when starting and stopping, but at least you are using only one remote.
Hope this has helped.
Nov 19, 2010 | One For All URC-3021 Remote Control
Dish network code for a viore, volume/power not working
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Apr 05, 2010 | Toymax Viore 42 in. Plasma TV
Avex universal remote programming for Viore TV
Have you tried the search method?Turn the tv on manually. Hold the TV button and the SELECT button down together on the Avex remote until the light comes on. Then use the up (or down) arrow button to scan the codes. Use the up (or down) button slowly but quicker than 30 seconds. If it comes across the right code the tv will turn off. If the set goes off press the power button on the remote to turn the tv back on and test the volume and channel buttons for operation. If some of the buttons don't work continue pressing the up (or down) button until the tv cutts off again. When (and hopefully if) you find the right code press the TV button on the remote again and the light will blink 3 times to indicate it is programmed. I do hope this helps and thanks for using Fixya.
Nov 05, 2009 | Televison & Video
Cablevision remote won't work viore tv
I was able to program my viore tv by trying the code search:
1. Press the tv and sel buttons until the IO button turns red.
2. Press channel up or down until the tv turns off and the press the tv button to lock in the code.
Ps: Be pattient when searching for the code, it might take a while. HOPE THIS HELPS!!!!!!!!!!!!!!!!
Mar 09, 2009 | Toymax Viore 42 in. Plasma TV
Code for a tv remote
if u have a universal remote and none of the codes seem to work after trying all the codes and non still don t work follow these steps
1. make sure the power on the TV is turned on
2 press and hold code button until it flash twice
3 then press the TV mode button until the light flashes the press
4 power button until TV powers off
Feb 13, 2009 | Daewoo DTQ-20U4SC 20" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
