Question about Dell E173FP 17" LCD Monitor
Dim monitor Can not brighten monitor so it is readable. Is there a control to brighten monitor
    Guru:
  • 285 Answers
  1. goto this link for the manual and see it
  2. http://www.scribd.com/doc/20433804/Dell-Lcd-Monitor-e173fp
Posted on Jul 13, 2010
My Rockford fosgate with removable faceplate 9210 is to dim to read when I lightly press the top of the face bout the middle it brightens up a little bit.
Try hooking up the accessorie wire it controls the power to the auto dim and brighten it just needs to be hooked into the 12v memory wire
Oct 26, 2013 | Car Audio & Video
Black display
You say black display. Not sure what you mean. Either the monitor is working or it is not. If you see nothing on the monitor and the power light is yellow, then it is not getting a signal.
If the power light is green and you see nothing, look really closely. You might even shine a flashlight at the monitor to see if there is actually a dim display. If so, the backlight has gone out and needs to be replaced.
I'm assuming that you have tried to brighten the display with the monitor controls.
Jan 09, 2012 | ViewSonic VA720 17" LCD Flat Panel Monitor
How do I brighten the monitor on my lenovo T61?
I believe the T61 is like my T60.
The "Home" and "End" keys will act to brighten or dim the screen when you hit them as you hold down the "Ctrl" key.
Dec 20, 2010 | Lenovo ThinkPad T61 Notebook
MY ACER MONITOR IS DIM , HOW DO I BRIGHTEN IT UP?
Push the button on the front that says menu. Within that menu you will find the brightness control. Use the other buttons to move through the different menu items until you get to Brightness. Once there push the menu button again and then adjust the brightness with the other buttons.
Nov 27, 2009 | Acer AL1916W 19" LCD Monitor
My Garmin nuvi 1300 brightness problems
I spoke to Garmin Support about this issue. There are 2 settings for contrast on the nuvi 1300. You need to set the contrast while it is plugged into the vehicle, and also while it is unplugged from the vehicle. The reason for the 2 settings is to save the charge of the battery while it is not plugged into the vehicle or power source.
Sep 14, 2009 | Garmin nuvi 1300 Car GPS Receiver
Lower half of monitor goes dim
Replace the backlight in this unit will bring you back in business.
Thanks please rate.
Aug 19, 2009 | Star Logic 17" LCD Monitor
I cannot adjust the monitor brightness, it's too dark..
Since this problem was posted generically.. Monitors, whether they are the old tank style CRTs, the newer flat panel LCDs or the newest LEDs, all have 'Brightness' controls. All are typically marked with what looks like a bright, or radiant light bulb, usually offset to one side, to show that "adjusting the ?? that way" will brighten the screen. Most LCDs are now Menu Driven, so looking for a button that says "Menu" is your starting point. You will need to find your adjusting control and the 'light bulb' to figure out which way to brighten or dim your screen. Once found, adjust to eye pleasing brightness. If your brightness is at 100%, you are on your way to needing a new or used monitor. Typically, there is no Brightness settings in the operating system. Your enhanced video card maybe doing it to you, They usually have their own control center and the types of abilities vary greatly. If you hav a friend that can loan you a monitor, borrow it to test at least the output your monitor is receiving. That will tell you whether you are having a problem with your video card or your monitor.
Aug 18, 2009 | Dell (H5195) Laptop Cooler, CPU Fan,...
2009 Toyota Yaris - Can't see the speedometer when it's sunny.
somewhere around your headlights or dome light switch there should be a knob or roller switch that will dim or brighten the panel
Apr 13, 2009 | 2009 Toyota Yaris
HP dv1000 monitor just stopped working.
Description During the startup or boot process of the notebook, the display is very dim and barely readable. It remains dim when it reaches the Windows desktop. Restart the notebook with AC power Perform the following steps to determine if the dim display is due to a hardware failure:
  1. Connect the AC adapter to the notebook and a working electrical outlet.
  2. Power down the notebook PC by pressing and holding the Power button for 5 seconds.
  3. Press the Power button again to start the computer.
If the display is still dim after restarting with the AC adapter connected try changing the LCD brightness. Change the LCD brightness From the Windows desktop, hold the Fn key and press the F7 and F8 keys to increase or decrease the brightness of the display. If using the function keys does not resolve the problem, determine whether the Lid Actuator switch is stuck. NOTE: The key number may vary depending on the notebook PC. The image on the key should resemble the following images: Figure 1: Brightness Level Down c00776225.jpg Figure 2: Brightness Level Up c00776226.jpg NOTE: During battery power operation, the notebook display will dim to reserve battery power. Adjust brightness control using the control panel Some notebook PCs have the ability to adjust the brightness through video drivers. If the notebook PC has video drivers with this capability, perform the following steps:
  1. Click Start , Control Panel and then double click Display .
  2. Select the Settings tab and click Advanced .
  3. If the feature is available, a tab with the video card name will be present. If it is, select that tab.
  4. Adjust the desired brightness.
Finding the Lid Actuator switch The Lid Actuator switch is a small button or switch located above the keyboard and LEDs on the right or left side of the notebook. It may also be located near the display hinges. Pressing this switch when the computer is on may turn the notebook display off or cause the notebook to enter a different power state. Press the switch 2-3 times while observing the display. If the display is no longer dim the switch may need to be repaired. Contact HP service and support for further assistance. Contact HP service and support If the display remains dim after the troubleshooting in this document it may be possible that the backlight is damaged. Please Contact HP service and support to schedule a repair
Jun 05, 2008 | HP Pavilion dv1000 Notebook
Dell E173FP 17" LCD Monitor Logo
302 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
