Question about Uniden BC350C Base Scanner
Programming a frequency
Can anyone tell me how to put a frequency into a uniden bc355c base scanner please
  • shokee595 Jul 14, 2010
    thank you for your help i appreciate it very much
  • 821 Answers
Hello,The BC355C is an oddball unit that does not allow true manualprogramming. You cannot take a list of known frequencies and programthem into the scanner. Instead. a frequency must be located (anddisplayed) during a search or scan operation in order to be programmedinto scanner memory. Need the manual for your scanner? You candownload/print it free of charge here:
http://www.uniden.com/pdf/BC355Com.pdf
wish you good luck,
take care.
Posted on Jul 14, 2010
What is the difference between uniden bc355c and bc355n
about $25.00. I don't own ,or have ever used a scanner but I would have to say it has a feature that the other one doesn't have.
Jul 06, 2013 | Uniden BC355C 800MHz 300-Channel Base...
Have a new uniden bc355c scanner. How do i program frequencies into the private channel so that those are the only frequencies scanned.
With all due respect, I suggest reading the user manual that came with your scanner. The user manual is the best reference material there is. for this product. If you need frequencies go to www.radioreference.com
Jul 09, 2011 | Uniden BC350C Base Scanner
Easy way to program my bc355c scanner
The BC355C is a factory pre-programmed scanner, and it cannot be programmed in the usual manner (entering and saving a frequency via the keyboard). You can, however, transfer any displayed frequency in the SEARCH or SCAN modes to the scanner's PRIVATE banks, saving it for later scans. Detailed instructions for doing this can be found on pages 49 through 56 of the factory manual. If you don't have the manual, you can download and print it, at no cost, here:
Bill B.
Listening in since the 60's
Apr 10, 2011 | Radio Communications
We cant figure out how to program our bc355c scanner and where to find the codes so we can get it programed and start using it
The BC355C is a factory-programmed scanner, and you cannot program it in the normal manner (entering frequencies via the keyboard). You can, however, transfer a displayed frequency in SEARCH or SCAN mode to your PRIVATE bank. Detailed instructions for doing this are in the factory manual that you can download and print, at no cost, here:
You can find a comprehensive database of active frequencies in your area (they're not codes), and a lot of other useful scanning information, here:
www.RadioReference.com
Bill B.
Feb 19, 2011 | Uniden Radio Communications
Can i program my bc355c scanner to scan only the channels i programmed?
Yes, once you have programmed/transferred frequencies into the PRIVATE bank, with the scanner powered ON, press the PRIVATE key to start scanning. Need the manual for your scanner? You can download and print it, at no cost, here:
Bill B.
Jan 31, 2011 | Uniden Radio Communications
Is there a video on how to manually program the bearcat scanner BC355C 100 channel to put in my area frequency into the scanner?
Sorry, but there is no such video that I know of. Besides that, your BC355C is not a programmable scanner in the standard sense, in that you cannot enter frequencies via the keyboard. You can, however, transfer a displayed frequency from the SCAN or SEARCH mode into the PRIVATE bank. Fairly simple instructions are in the factory manual that you can download and print, at no cost, here:
Bill B.
Jan 13, 2011 | Uniden BC350C Base Scanner
How do you program a uniden bearcat scanner bc355c
Turn on the radio
Press the "band" button
Keep pressing the "band" button until you come within the parameters of the frequency that you want
Let the radio scan until it gets close to the actual frequency that you're looking for
Press the "hold" button and use the arrow "up" or "down" button till you lock in the correct frequency
Once you have the frequency locked in, press the "program" button
Press the "private" button
The unused channel will be flashing
Press the "program" button, this locks the frequency into that channel
Continue this process until all of the frequencies are loaded into the radio
Jan 05, 2011 | Uniden Radio Communications
How do you manually program a Uniden BC355C?
Turn on the radio
Feb 22, 2010 | Uniden BC350C Base Scanner
Free loco frequencies
For a comprehensive database of active frequencies and systems in your local area, and a lot of other useful scanning info, visit:
BillB
Feb 10, 2010 | Uniden BCT8 Base Scanner
New BC355C put 7 channels in,but only will stop on 2
1. Be sure sure that your squelch is adjusted properly. While scanning, turn the SQUELCH control down slowly until scanning stops and you hear a hissing sound. Then slowly turn the control back up until scanning resumes. That will set a proper threshold level for the frequencies you're monitoring.
2. Be sure that signals are not blocked in your area. Topography plays a large part in VHF and UHF radio reception. A hill, a tall building, even a thick grove of trees can prevent a signal from reaching your antenna.
3. It's possible that there was just no traffic on the five freqs while you were listening.
4. Be sure that the frequencies you've programmed are assigned in your area.
5. For a comprehensive database of active frequencies in your area, visit:
BillB
Jan 26, 2010 | Uniden BC350C Base Scanner
Uniden BC350C Base Scanner Logo
110 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
