I can help you with your Panasonic TC-32LX70 LCD HDTV digital channel problem.
I recommend you start troubleshooting your channel problem by having your TV rescan its digital channels. Since you haven't mentioned a set top box or PVR of any kind, I am going to assume you are either using your TV's built-in tuner with either an antenna or cable tv service source.
Follow these steps to rescan channels for your HDTV's built-in tuner:
On your remote
Press MENU.
Select SETUP with the arrows & press OK.
Select PROGRAM CHANNEL with the arrows & press OK.
Select CABLE (or ANT IN if you do not have a cable service provider) with the arrows & press OK.
Select AUTO with the arrows & press OK.
Select DIGITAL ONLY (to rescan for your 'missing' digital channels) with the arrows & press OK.
Select APPLY with the arrows & press OK.
This scan will take some time, but should reprogram the lost digital channels that you expect to be able to tune in.
I hope that helps.
______________________________________
Panasonic TC-32LX70 Manual
Download
