Question about Intex 15' X 42" Easy Set Pool Complete Pool Set
Pull the lid back off and check the O-ring...it is not seated properly...reinstall the lid and you will be okay...
heatman101
Posted on Jul 13, 2010
Jun 01, 2014 | Sta Rite Sta - Rite 24" Sand Filter & 1 Hp...
Oct 25, 2010 | Intex Automatic Salt Water System for ...
Thank you for posting your question here on Fixya.com.
Have you checked your water for acid levels to ensure you have enough to maintain your chlorine level? Adding stabilizer (cyanuric acid) helps the chlorine remain in the water longer and if you had to replace much of the water since your chlorine levels were OK you need to add more stabilizer to keep the chlorine in the pool. Have you altered the amount of time the pump runs too? An erosion feeder like yours only adds chlorine when the filter system is running. If you have scaled back the amount of time the equipments runs you will also be adding less chlorine over time than you previously had.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Oct 10, 2010 | Pool & Spa
Sep 29, 2010 | Jandy PHP High Head Pump 2 HP Up rated
Jul 07, 2010 | Waterway Twm Above Ground Pool Pump and...
Jun 13, 2010 | Pool & Spa
Oct 04, 2009 | Plumbing
Aug 13, 2009 | Intex Automatic Salt Water System for ...
Jun 10, 2009 | Hayward In Line Chlorinator 9 Lb. Capacity...
Jun 09, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Jul 24, 2011 | Intex 15' X 42" Easy Set Pool Complete...
109 people viewed this question
actually figured it out. we had the in and out backwards. working now :-)
