Question about Dometic Rooftop RV Air Conditioner
My a/c compressor keeps kicking on and off
My compressor keeps kicking on and off, about every 5 - 10 minutes or so, even when the thermostat and fan are in the off position. It stays on for approximately 3 - 4 minutes. Why is this happening?
4 Suggested Answers
SOURCE: Ruud 5-ton 10 SEER heat pump compressor turns off after 20 minut
You may have cottonwood on your compressor. Before you spend any money, do two things. Rinse off your compressor to clear any cottonwood, and check your filters, they may need to be replaced. Hope that helps!
Posted on Jun 24, 2009
farfield
  • 462 Answers
SOURCE: My air handler comes on ,not the outside unit when
If you have a standard thermostat the fan switch is for the air handler only. It completely over rides the thermostat for most settings. Now lets see this is what I'd expect:
fan switch on Indoor fan runs all time
Fan switch auto Indoor fan only runs when thermostat is set to cool or heat and the thermostat is turned up above room temp for heat or below room temp for cooling. In both of these modes the furnace blower comes on and stays on til the room temperature is satisfied. The outdoor unit only comes on for AC the out door unit will not come on for heat or the "on" setting on the thermostat. See exception 1 & 2 below...
Exception 1- (in a heat pump the out door unit runs in both heat and cool mode unless it has emergency heat turned on then it will not come on outside in the heat mode, and depending on the type of heat pump and furnace or air handler it is). A heat pump thermostat usually has "backup heat" and an "emergency heat" setting switch on the thermostat.
Exception 2 - On some thermostats they are made to cycle on the heat if the temperature reaches a preset temp (around 50'f usually but definitely by 40'f). This mode prevents freezing when if instance the homeowner is away or while the home is under construction. In this mode the fan inside can run but the heat usually comes on with it.
Exception3 - On some electric furnaces the heating strips may be individually controlled and thus not all come on at one time. This may give the feel of no heat especially if the room is cold.
Now there may be other exceptions but Ive tried to give you a heads up on some of the most common ones.
If you need more help please post more specifics about your unit/system as to for sure what switches are set to what setting and what is happening with each. My first though was that maybe your system is OK and you needed to know if the thermostat was working properly.
If this helpd you understand your problem would you please give me as hifgh a mark as you can. Thnaks for using fixya and good luck.
Posted on Mar 28, 2009
  • 588 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
Auto/On set to ON. Fan runs.
Sounds like the thermostat, the way to verify is to unplug indoor unit, remove thermostat, take pic of wiring with phone or label the wires as to the terminals. Carefully twist the yellow,(Y) Red (R) and the green (G) together. Plug the furnace back in, if the unit operates normally, replace the thermostat. I am basing this on the fact that the blower speed is changing. This could also be an anomaly within the circuit board in the furnace section, not likely though as the outside unit (condenser) is not controlled n by the indoor board unless this is a heat pump. hope this helps. D
Jul 21, 2015 | Dometic Rooftop RV Air Conditioner
Can hear compressor, cois get frosty but fan cuts out after five minutes. Why?
IF THE FAN IS CUTTING OUT U MAY HAVE STUCK TIMER IN THE DEFROST CYCLE MODE BUT MORE LIKELY U HAVE A POWER ISSUE, IS THIS A digital cold control thermostat? if so the control board itself may not be communicating with the thermostat, when the fan cuts out does the compressor keep running? and no clicking sounds?
Mar 16, 2015 | Refrigerators
Fan will come on but compressor wont kick in on wall unit ac
The start capacitor on the compressor is bad. Replace it and the compressor will run.
Jun 30, 2013 | Heating & Cooling
COMPRESSOR RUNS A LOT
Your model has a mechanical thermostat inside the control panel. I believe you have something else going on like a bad fan, start relay, capacitor. Something is causing the compressor to struggle to keep up and in turn causing the compressor to short cycle. If the thermostat has no control over run time then something like I explained is causing the problem. Here is a parts manual=> ED5VHEXVB04 Contact me if you would like my help, Thanks Sea Breeze
Feb 26, 2013 | Whirlpool Refrigerators
I cannot get my wintair room air conditioner to stay on! It keeps cutting on and off, going from fan to air conditioning. Need help!!
It sounds like your air conditioner is doing what it is supposed to do. The compressor kicking in and out is an energy saving method of using the ac. When the thermostat (ball attached to evaporator coil) registers the set temperature the compressor kicks off.
Jun 28, 2010 | Heating & Cooling
Fan motor keeps kicking on.
You must have a bad compressor relay
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 22, 2009 | Refrigerators
Carrier air conditioner cycles on and off
The compressor/condenser is being called all the time. The reason it goes off is because the evaporator (indoors) freezes up when the fan is told to turn off by the thermostat. This further cooling lowers the low side pressure below the low limit switch point turning off the compressor unit.
Solution: Make sure the thermostat is wired correctly. Green wire is usually the compressor wire but maybe not.
Jun 17, 2009 | Carrier 38BRC036 Air Conditioner
Comperssor kicks on but quickly cuts off intermittently every 5 minutes on my frigidaire fridge side by side
Freezer defrosted everything fan continues to run but will not freeze. Compressor is cycling enough to keep refigerator section cold. 106 Series Kenmore. Turned up thermostat to keep fridge cold and a shorter intermittent compressor cycle run
Jun 06, 2009 | Frigidaire FRS26H5AS Side by Side...
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
363 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
