Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
Where can I get a manual?? Hitachi EC12 Compressor
How much oil in an ec12 hitachi air compressor..... brand new. no oil. no manual.....
DO NOT FILL to the plug threads on this compressor!!! The dipstick has a mark and it is very near the end of the stick. Any more questions please email or repost.
Tim
Sep 22, 2011 | Hitachi EC12 Portable Electric 2hp Air...
What type oil does the Hitachi EC 12 use? Ray
SAE 5W50 and if available use full synthetic.
This link will take you to the EC12 owners manual if you would like.
http://www.hitachipowertools.com/product/files/pneumatics/compressors/EC12__OM.pdf
Oct 28, 2010 | Hitachi EC12 Portable Electric 2hp Air...
I got a used Hitachi ec12 compressor, it doesn't start.
1.Check the motor first. You can readily see if it's
burned or not. Run a megger test on the motor.
Test run the motor without the compressor.
2. If, it does not run, have it checked at the motor
rewinding shop.
3. Once it is okey, remount the motor, and start it up.
Oct 29, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Do not have manual for hitachi ec12 air compressor, cannot increase pressure
You have to manually adjust the pressure regulator. Make sure drain is completely closed. The one thats on the bottom of the tanks
Aug 29, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Lost my ec12 manual in a flood out need to replace it
can get manual from where you purchased the unit if purchased new http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/hitachi/EC12
here you will find a parts manual
Jul 10, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Ec12 hitachi air compressor will not build pressure higher than 40psi
most likely the the reed valves are stuck or miss aligned. Worse case senerio your piston seal blew causing this not to build pressure. Read manual on how to disassemble head. to remove should be 4 bolts and your copper line, just be careful of the reed valve plates, they are thin steel that sit into the head. Put back the same way you took it apart.
Feb 28, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi ec12 motor hums after drop in pressue
There should be a pressure switch adjustment under the cover of the switch remove the cover and reset.
Feb 03, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
128 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
