Question about Car APS255A 2 Prestige Platinum Code Learning 3 Button Security Sy
Unable to disable the alarm. - Car APS255A 2 Prestige Platinum Code Learning 3 Button Security Sy
  • 1,284 Answers
Hi, to try to disarm it, look under the dash area for a button or, a toggle switch. When you locate it, turn on the ignition key, press and hold in the button (little spring loaded micro button, red or black possibly) until the alarm chirps 1 time. This should over ride the system, and only the keyless entry part, if installed, would still be operating. The LED (light emitting diode) light in the dash should also go on solid.=VALET/OVERRIDE This stops the alarm except for the keyless entry if installed. Once in Valet mode, it will allow the car to start and operate like there was no alarm at all. The next step is if wanting to remove it, you contact a local technician to locate it, and affect necessary service for you. Take care
Posted on Jul 13, 2010
  • devon_lemons Jul 13, 2010
    If I simply unplug the brain, will that do as well because I believe the PBLED is malfunctioning?
  • Shehu Pro
    Shehu Pro Jul 13, 2010
    O.k, you can unplug the brain.....
    Take care
How do I permanently disable a DEI Automate car alarm on our 1999 Acura Integra.
Just remove it. It shouldn't be too hard, take all the parts and harness out, reconnect any cut wires and wrap any exposed wires with electrical tape.
May 31, 2015 | 1999 Acura Integra
Disable alarm mitsubishi
Check for a failed car battery
Jul 30, 2014 | 2003 Mitsubishi Eclipse Spyder
How do I disable alarm on land rover discovery?
Easiest way is to find the manual on line, if you do not already have it, and pull the fuse for the alarm. That should disable it. Then next dealer visit you can have it reset and you'll be good to go.
Apr 01, 2014 | 2000 Land Rover Discovery
Disable factory alarm
Fuse boxes are usually located under the dash, or on the side of the dash(open front doors) and..also look under the hood fir all larger fuses in another fuse hox
Oct 01, 2013 | 2006 Suzuki Grand Vitara
Unable to disable my security system/alarm on my 95 Chev. Camero
yes, do some internet searching, I believe there is a control that you unplug inside the hatch on the left hand side, remove the inside plastic panel, undo the connection, wait 5 minutes then reconnect. This I have done once along time ago on a 94 model. Remember I am only here to help and wish this works for you. Good luck.
Dec 16, 2009 | 1995 Chevrolet Camaro
Unable to open doors with key due to discharge battery
you should not have a problem with this as the key is located in the remote and the alerm will sound but as soon as you put the key in the ignition the vehicle cancell the alarm[sword key in the remote
Jul 21, 2009 | Anti-theft Alarm System 3 Series E90 E92...
New battery -alarm sounds- have to disconnect the battery-
The sounding alarm maybe a security system installed by in the truck. Disconnecting the battery will only temporarily solve your problem, but will resume once you reconnect the battery for electrical power.
You must find the keychain/remote of the security system and disable it. If you are unable to locate this, you can have it disconnected by a qualified automotive electrician.
Word of caution though, if you are using the keyless entry system with the security system, this will be disabled until you install a receiver with such function.
Hope this helps.
Jun 29, 2009 | 1999 Nissan Pathfinder
1988 nissan maxima factory alarm faulty
try locking and unlocking the doors with the keys that is what i did and it solved my porblem
Jun 23, 2009 | 1988 Nissan Maxima
Car APS255A 2 Prestige Platinum Code Learning 3 Button Security Sy Logo
114 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
