Question about Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer
Troubleshooting item 46
Will not print states item 46 in trouble shooting guide that I no longer have !
    President:
  • 405 Answers
You could check for a paper Jam or foreign oblect in the machine, under the top cover and in the back cover.
If there isnt a Jam in the machine it means there is a mechanical problem. There is a sponge in this machine and once it is full it wont be able to absorbe any more ink from the cleanings. You will need to bring it in for services, they would replace the sponge and reset the cleaning counter.
check the brother website for an authorized service center in you're area.
Posted on Jul 15, 2010
Dcp-165c clean unable trouble shooting and routine maintenance chapter in user's guide 46
for non fax models ie I have DCP 165C you say press ...... press up arrow four times then press 8 then 0 etc ... but I have no numbers to press!
Jul 15, 2012 | Brother DCP 165C Compact Color Inkjet...
ERROR : CLEAN ENABLE 46 troubleshooting and
If you look at the Brother website you will find a trouble shooting guide for your machine.
In the guide, for the error you quote Brothers guidance is to check for a stuck piece paper, however it also states that if the printhead is hard over to one side (righthand side if memory serves me correct), then to contact Brother. If you do so, Brother will tell you it needs to be serviced by a Brother agent, which will likely cost you more than a new one !
If it isnt a stuck piece of paper, the problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Nov 03, 2010 | Brother MFC295CNAll-In-One InkJet Printer
My brother mfc 420 cn says unable to clean see troubleshooting guide that i know longer have
Oct 05, 2010 | Brother MFC 420CN All-In-One InkJet...
Clean unable 46, See Trouble shooting and routine
When you are doing cleaning process many times, You Purge Countergets overflown, You need to be reset the same by some technical rest code required. By pressing - menu -start - menu , Just go in reset counte and reset the same
May 12, 2010 | Brother DCP 165C Compact Color Inkjet...
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
How can I clear unable 46 with my brother MFC_240C USB printer ?
In the guide, for the error you quote Brothers guidance is to check for a stuck piece paper, however it also states that if the print head is hard over to one side (righthand side if memory serves me correct), then to contact Brother. If you do so, Brother will tell you it needs to be serviced by a Brother agent, which will likely cost you more than a new one !
If it isnt a stuck peice of paper, the problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code soemwhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Dec 30, 2009 | Brother MFC 240C All-In-One InkJet Printer
DCP 115C does not print
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely
the manual states for this problem
"The machine has a mechanical problem.
OR
A foreign obstacle such as a clip or ripped
paper is in the machine."
Aug 05, 2008 | Brother DCP 115C All-In-One InkJet Printer
Will not print
You have a major error, probally head stuffed error 41, to find out your error press menu starte and up 4 times, this may show error if not then input 82 set, error will display.
Post back if need more info
S.
Jan 14, 2008 | Brother MFC-5440CN All-In-One InkJet...
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer Logo
323 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
