Question about Sharper Image Deluxe Spire SI788SNX Tower Fan
I have model s1698 which has been working fine. Now my tower fan is too noisy. I have cleaned the front filter section but the noise continues.
Noisy
The noise could be from dust that gets in cpu fan or power supply fan. Clean them but do not open the power supply. Better replace your power supply.
http://pcsupport.about.com/od/nonworkingcomponent/ht/fannoisetb.htm
Mar 14, 2012 | Codegen PS-400W-12 (PS400W12) 400-Watt...
Did not help so fare.
bearing may be to far worn, go get new one
May 06, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Grinding noise in tower
Grinding noise in tower If everything on your computer is working fine then it is probaly a fan put your ear in the back of your tower near the power cord and see if you can hear the grinding noise better if you can then your power supply's fan is going out if not its probally one of the inside fans in your tower open up your tower and see if you can find which fan it is if you dont want to do this you should probaly get a tech to look at it it's a pretty cheap fix and it can save your computer from heat dammage
Nov 07, 2009 | Computers & Internet
Squeak in aloha breeze tower fan model 05538
If the model is equipped with a fan, and the noise occurs even when not oscillating it must be a fan/blower motor. If it is a squeak. A squeal could be an electical component going bad which is always bad. I would definitely take some bottom drawer tools , ie. screwdrivers and WD-40 and oil that squeaking motor. Being a fan it goes through alot of air pollutants. That tends to build up on the shaft and can work its way into the bearing seal. Good luck.
Jun 28, 2009 | Tower Aloha Breeze Fan
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
Noisy
there are two screws on the back of ur tower for each side supporting plate .remove the side plate which is on the other side of ur motherboard.then just blow out all the dust with a air blower.
Dec 22, 2008 | Gateway 504GR PC Desktop
Noisy fans laptop overheating?
Try using Compressed Air in a can by the vents. I would not recommend taking apart the laptop.
Dec 22, 2008 | Computers & Internet
Fan noise
Generally fans on lower end cases are fairly cheap. I've had several new ones that make lots of noise new. You can call the manufacturers tech support and mess around tryig to get a replacemet or you can just order an inexpensive replacement fan. Cyberguys is where I typically buy my replacements. http://www.cyberguys.com/templates/searchproducts.asp?categoryID=191
Sep 18, 2006 | Vtech 8870KL ATX Mid-Tower PC Micro ATX...
Sharper Image Deluxe Spire SI788SNX Tower Fan Logo
223 people viewed this question
Top Sharper Image Dryers Experts
Dan Webster
Dan Webster
Are you a Sharper Image Dryer Expert? Answer questions, earn points and help others
