Question about Fisher and Paykel GWL11 Top Load Washer
My fisher paykel gw11 takes an hour to complet cycle! Is that normal? What could be wrong?
  • 343 Answers
Most likely cause is reduced water flow to machine. This could be because the filter on the inlet valve is partialy blocked or because the inlet valve is faulty. Check the valves where the hoses screw onto the rear of the machine. You may also like to check the flow rate of the cold or hot water. Cold water inlet valve problems are not unusual for F&P washers. They can sound OK, but have weak flow..Good luck....Please take a moment and rate this answer.........Nomess
Posted on Jul 13, 2010
Gw11 stops mid cycle and beeps and lights 2 and 7 are lit up anybody know what the error code is
Is it model GWL11? There is no model GW11. On most other models that code indicates there is a fault in the water pressure transducer which measures the water level. Unfortunately the motor controller module needs to be replaced.
Nov 06, 2014 | Fisher and Paykel Washing Machines
Connecting motor controller in gw11 washer
There is raised print below the socket with the name for the plug that goes in that socket.
Feb 15, 2014 | Fisher and Paykel Washing Machines
Burning Smell on Fisher and Paykel GW11 on spin and is not getting up to speed on spin cycle. Motor Bad?
Hi just read your posting.In my experience the only part on a Fisher and Paykel top loader machine that creates a burning smell is the pump.Try looking under the machine and you will see a black fan.This is your pump.Check to see if it has corrosion on it with a torch and try smelling it.I am sure you will find it is the pump that is smelling.Please reply for additional help and tell me how you got on with checking the pump.Looking forward to your reply.
May 14, 2011 | Fisher and Paykel GWL11 Top Load Washer
Have Fisher & Paykel washer GW11. 5 yrs old. Lid won't lock, Took off to repair, then put back on, no problem, but now won't lock, so won't spin. Help!
your door needs to be re-aligned so the wax motor assy can lock the door so the unit senses its locked and can continue the wash cycles
Jul 16, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have purchased a house with the single door dishwasher and it takes forever to wash - about two hours - what could be the problem?
Check your program settings. If wash quality is good, it's OK. Check your inlet water has sufficient pressure! Refer user manual
Apr 07, 2010 | Fisher and Paykel DS603SS Stainless Steel...
Fisher and Paykel dishwasher noisy fan
Have you got your dishwasher on an extended drying cycle?
Normally it works for about 10 minutes after the wash cycle is complete - not hours.
Jan 21, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water not coming with force in Fisher & Paykel SmartDrive Top-loa
Try taking the cold hose of at the tap and check to see if has a little mesh filter in there. This could be blocked up with gunk.
Jan 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Where can you find a fisher paykel GW11 pump for $25 as quoted in your response? Thanks!
go online to fisher & paykel factory parts search and you have to look but they are in there I dont remember $25.00 but its close
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
88 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
