Question about Daewoo Refrigerators
Can I pulg in my Daewoo fridge freezer before it's plumbed in? Could you let me know if I can plug in my new Daewoo fridge freezer, before it's plumbed in for the ice and water dispenser? I don't want to damage it before a plumber comes out but would like to know if I can start to use the fridge and freezer.
dididsaythat
  • 291 Answers
SOURCE: GE SIDE BY SIDE FRIDGE FREEZER
Need more info on this whats is beeping? do you have any error codes, when is was plugged in... was ALL the fans blowing.. freezer fan and fan below by compressor? was there any frost on the back wall of freezer?
Posted on Sep 01, 2007
peyton32034
  • 410 Answers
SOURCE: Daewoo American Fridge Freezer FRSU20DAI Ice/water dispenser
your refrig should work just fine without water connected to it. just make sure your icemaker is not turned on. it will not harm you refrig to use it without water connected..
Posted on Dec 14, 2007
SOURCE: Water & Ice do not dispense. Maytag ICE2o
Possibly the water valve (also known as a solenoid valve) on the back of of your refeer has gone ka-put. It is easy to find and spot. The water line from your source (out of the wall) goes to this valve. If it is not operating, you will get no water supply thru that line into your dispenser or your ice-maker unit. No water in means no water and no ice out. This is a pretty simple fix you can do yourself. The part is reasonably priced. Get the model number of your refrigerator off the door and contact your local distributor for your brand. Make sure you turn your water off at the wall, or house, before you start taking that plumbing line apart. Otherwise, get yourself a surfboard and lay in a good supply of paper towels. Take your time and unplug your unit from the wall to be on the safe side...
Posted on Mar 06, 2008
t0pc4t
  • 132 Answers
SOURCE: water dispenser inside fridge does not dispense water
Are the water inlet / outlet correctly fitted onto the filter ??
Sounds silly - but very easy mistake seen several times.
Is the water supply for the filter turned on . . remove hoses from filter to verify. - YOU WILL GET WET.
Posted on Aug 15, 2008
SOURCE: Fridge Freezer Ice maker problem
We have an Whirlpool side by side America fridge freezer. Water is not flowing into the ice-maker
Posted on Apr 10, 2009
My Daewoo American fridge freezer is not making ice in the ice compartment and food have started to defrost but you can hear the fridge freezer working
How old is the fridge? If it is old I suspect the compressor is not functioning as it should. Things to check before calling the repairman or buying a new one: The thermostat setting. Be sure there are no air leaks around the door seals.
Jan 10, 2018 | Daewoo Refrigerators
Daewoo fridge freezer just isn't powering up at all. I plug it in but then nothing
OLD or NEW check setting knobs inside to make sure they are not turned to 0 =OFF
Sep 23, 2017 | Daewoo Refrigerators
Top of freezer not freezing
your cooling matchine get damaged,there having a cooling matchine.
Mar 25, 2013 | Daewoo FRSU20IA Freezer
Ice forming at bottom of Daewoo freezer. How do I fix this
Look on the back of the unit for a plastic hose coming out the bottom to a drain pan usually sat on top of the compressor. Bend a straw and push up inside. If it won;t go, there is a blockage, usually ice in the drain. Fully defrost the freezer and blow through the straw until clear.
Apr 28, 2012 | Daewoo Freezers
Fridge not cold enough and freezer not producing ice cubes
how does any tradesman(person) know how much its gonna cost before they even look at it.....
i would suggest you call a small,family run,electrical shop.
they have a reputation to uphold......
Jul 21, 2010 | Daewoo Refrigerators
Ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
Jul 19, 2009 | Daewoo Refrigerators
Refrigerators Logo
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
