Question about Gilmour Garden
Sprayer spits while spraying
Sprayer spits
  • 43,501 Answers
When that happens it is usually because you have dirt in the nozzle or it has not been clened properly.
Replace the nozzle or clean it...
heatman101
Posted on Jul 13, 2010
2 Suggested Answers
  • 10865 Answers
SOURCE: sprayer is spitting instead of spraying, why?
Either the fluid you are attempting to spray is too thick or the little holes in the spray head are partially clogged. Begin by running some small copper wire thru each hole to unclog it and see if that solves your problem. If not, filter the liquid you want to spray and dilute it as needed.
Posted on Apr 15, 2009
I have a Kraft tool texture sprayer 500 model, I have noticed lately that the oil is slowly syponing out of the holding tank and its running into the air hose so when I turn it on it spits out oil lef
As the hopper gun does not use oil, you are either spraying an oil based material which is separating in the hopper, or you are using a compressor that is leaving oil in the airline; this could happen if the compressor is worn and oil is leaking past the piston into the air.
Nov 22, 2014 | Kraft PC501 Standard Texture Gun & Hopper
Spitting
most paint spray guns require the paint to be thinned this may be the cause of the spitting
Apr 15, 2014 | DeVilbiss Jga-510 Paint Gun Sprayer Item...
Shoots drips
Most airless spray guns spit a bit when you pull or release the trigger because the paint between the spray tip and the paint valve is under pressure but not enough to atomise the paint. If you increase the pressure you may reduce the spit to a point when you don't notice it. A blocked filter could slow the paint getting through to the tip cause lower pressure.
Jan 03, 2014 | Wagner SprayTech Wagner Airless Paint...
Paint gun not shooting correctly
Seeing how you have really stated what the problem is (spitting, clogged, won't shut off, fan pattern wont adjust Etc) and there could be several different things wrong- lets go over some basic spraying A B C'S- always strain the paint through a strainer bag or cone this will remove any debri that might clog the tip, *THINNING when you spray or atomize paint it should always be thinned it will actually cover much better if you thin it with the appropriate solvent water for latex thinner for oil base you want to stay in the 15% range alittle bit more on hot days. The shape of the spray that comes out of the tip is called "fan pattern" or "tip fan" "fan size" you can adjust the fan pattern from 9:00 - 3::00 or sideways to straight up and down or to a small circle this is done by moving the "tip housing retainer" keep a piece of cardboard to practice and see. IMPORTANT:When you have finished spraying you need to clean the entire gun by running the right solvent through the gun untill nothing but clean solvent is coming out dissemble the gun remove and clean needle and needle housing this is not very complicated and is paramount to maintaining any spray equipment for sure the gun....
Perry Tradesman
Dec 29, 2013 | GRACO INC 3900 Handheld Paint Sprayer...
Roundup battery propelled sprayer not working
Fix for electric spray wand not working that worked for me. Yes my wand would only spit out some foam, and nothing appeared to be clogged. The wand would spray just fine when I placed the siphon tube into a bucket of water.
Apparently what was happening was that the wand pump was creating a partial vacuum in the air tight canister, causing the electric pump to stop pumping. After all the battery pump is not all that powerful, just got a little foam. So I unscrewed the cap about one turn allowing replacement air into the canister and the wand started working.
Apr 06, 2013 | Garden
Using Ortho weed and crabgrass concentrate... what setting do i use on my Ortho hose end sprayer
Here is what they say at their site:
How do I use the Ortho Dial 'N Spray Multi-Use Hose-End Sprayer?
Pour product into jar, and set dial to amount indicated on product label and begin spraying. This sprayer siphons product and mixes while spraying; it does not mix inside the sprayer.
http://www.scotts.com/smg/catalog/productTemplate.jsp?bodyCssClass=scotts+blade+scotts+product+faqhelp+en&tabs=help&navAction=push&bodyId=product_faq_help&proId=prod70022&title=p_product_general_help_title&itemId=cat50094&id=cat50008
Which means it is not determined by Scotts, but by the product you want to disperse with the Dial N Spray.
And here is an exact description of the settings:
{ ... There are 14 settings in all and they range from 1 teaspoon per gallon up to 8 ounces per gallon. You will find the dial at the on the top of the sprayer. ... }
http://www0.epinions.com/review/Dial_N_Spray_Hose_End_Sprayer/content_465229876868
Aug 19, 2010 | Ortho Dial N Spray Hose End Sprayer
Herbicide sprayer stopped working
sometimes the tube/straw on the inside of the sprayer where the water comes thru falls off its connection.If you put the end of the hose in the sprayer you may have knocked it off.Depending on sprayer it can be easy or a pain to put back on
Apr 11, 2010 | Chapin Spectracide Sprayer
Sprayer is spitting instead of spraying, why?
Apr 15, 2009 | Garden
Sprayer Support
Measure the exact amount of material required for the job. Adjust the spray precisely - from coarse, drenching coverage to very fine mist to a long range pinpointed stream. Start and stop the spray quickly and at will. Prevent over-spraying by using the long-reaching hose and spray wand. Spray up or down as well as underneath leaves (where most insects and plant diseases can be found). Buy concentrated lawn and garden treatment materials, which in many cases is more cost-effective than the pre-mixed versions.
Aug 27, 2008 | Chapin Industrial 3 Gallon Viton...
Sprayer tips
Read and FOLLOW EXACTLY the spray material directions for mixing and use. Wear protective clothing including gloves and eye protection when spraying. Do not smoke, eat or drink when spraying; "wash up" afterwards. Spray on a calm day. Otherwise, winds may blow spray material off target. It's often best to spray in the early morning or late afternoon so excessive heat won't quickly evaporate the spray material. Follow the directions for use and maintenance that come with your applicator. Dispose of left over spray material and clean your applicator according to the directions on the spray material and with the applicator. Keep spray materials and applicator away from children and pets. Do not store spray materials in any but the original container in which they were purchased.
Aug 27, 2008 | Ultra Max R. L. Flomaster Atomist Electric...
Garden Logo
448 people viewed this question
Top Gilmour Garden Experts
Marvin
Marvin
cackelberry
Level 1 Expert
Charles T Nevin
Charles T Nevin
Are you a Gilmour Garden Expert? Answer questions, earn points and help others
