Question about Baumatic B609SS Stainless Steel Gas Single Oven
Oven door wont stay shut
It drops away about 100mm and is very loose
Oven door wont close tightly
Check the spring assembly tht shuts the door snugly. If spring is loose or stretched you will have the problem you are complaining about..
Sep 04, 2015 | Ovens
GE Built In Wall oven JTP25SOH6SS wont completely shut off
The cooling fan will stay on for a long time after using the oven. It should shut off after a while. If it is running all night for instance there is a great possibility that a relay is stuck on the control board.
Apr 13, 2014 | GE Ovens
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
Only heats when door is open - if you turn on to preheat, nothing happens unless you open the door - the light and fan will be heard coming on, if you shut the door it all turns off
there is a microswitch on the door inner it sounds like its come loose or broken away affecting its operating tolerances should be easy to replace.
Feb 15, 2010 | Bosch HBL 755 Stainless Steel Electric...
Oven door not staying fully open
phone bosch for clarification first. If this is not the case get the gas board out again
Oct 21, 2009 | Ovens
Door wont shut and the light stays on
Since this is a new install, check around the perimeter of the oven door and see if it is closing all the way flat against the surface. The hinge could have partially popped out and needs to be reset. Can you tell if the oven door is popped out at the top portion of the oven door or the lower portion of the door?
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Whirlpool RBS245PDS Electric Single Oven
U need to fit new door hinges, only solution as they are not adjustable.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
Loose Oven door handle
I would try putting some locktite on the threads so It wont come losse anymore.
Nov 07, 2007 | Ovens
Baumatic B609SS Stainless Steel Gas Single Oven Logo
22 people viewed this question
Top Baumatic Ovens Experts
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
