Question about Nisca PR5300 Thermal Label Printer
When maling a new card, there is a white line through the picture
When making new cards, there is a white line running vertical on the card. It feels as if the white line is engraved in the card.
The picture went out on my TV
This is not a user repairable issue and would require a TV repair shop. You may want to consider a new flat screen TV before spending the money on repairs.
Mar 02, 2015 | Televison & Video
Horizontal line with different color exposure above and below line on Canon Rebel t3i
Does this occur only on the camera, or is it visible on your PC during PP operations ?
Mar 25, 2017 | Cameras
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
There are white lines running vertically through my screen. on the sides the monitor shows the windows
The vertical lines could be caused by the Graphics card/Motherboard or the LCD screen itself. Try to unplug the LCD cable at the tower and look for the self test feature that will be displayed on the LCD screen. If the screen is good it means the Graphics card is faulty (if expansion) or Motherboard (if integrated).
Hope this helps.
Apr 02, 2010 | Dell E153FP 15" LCD Monitor
White vertical lines on screen. Unable to see pictures
check your graphics card connection to the motherboard when turned off. Try to install new drivers for the correct card. All else failts try a different monitor with same graphics card. If that doesn't work you know it's your graphics card. If it works fine, somethings up with the monitor itself.
Oct 20, 2009 | Apple iMac G4 Desktop
White lines across pictures
check the settings and yes you may have a bad card. try a new card, take a few pics and verify your camera settings as well.
Aug 24, 2009 | Canon PowerShot A95 Digital Camera
Vertical lines on screen. Can't see picture at
It sounds like you need a new screen.
Buy one on Ebay for 20 Euro (inclusive of postage)
youtube.com has great videos of how to change a screen.
You will need a tweezers and very small "philips" (cross/plus head) screwdriver.
Make sure the screwdriver has magnets....so that you dont lose some screws....they are tiny.
If you buy a replacement "LCD Screen Display" on Ebay then usually all the tools you need are included. (I just checked).
I also have just replaced my screen....screen was damaged...LCD leaked and lots of vertical lines on a now only WHITE screen.
Camera works fine now.
Check to see if the camera is still working.
Try taking some pictures....and then put the SD-card into your computer to see if the pictures are being taken.
Jul 14, 2009 | Kodak EasyShare V570 Digital Camera
Hello, Someone just game me their old pc, saying that the only thing wrong is the graphic card. The card installed is a Gainward GF2 MX-400 32MB GS (GK06428N031). The monitor is connected to CRT1. When I...
Well if you could open the pc and post me the model that reads on the motherboard to figure this one out, but if the card is build into the motherboard then only solution is to disable / turn off the video card and attach another card to the pc.
but if you can post me the brand / model that reads in the motherboard, its most likely on white text
if you look at this picture, the red circles, see the white text on the board, those details will be helpful..
Thank you
Nov 15, 2008 | Gainward GeForce2 MX400 (64 MB) AGP...
Nisca PR5300 Thermal Label Printer Logo
19 people viewed this question
Top Nisca Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you a Nisca Office Equipment and Supply Expert? Answer questions, earn points and help others
